aftermarket del sol headlight problems
Old 06-21-2006, 04:42 PM
digital sol's Avatar
Default aftermarket del sol headlight problems
i have some black 1 piecers with amber corners, was going to install them and noticed that the chrome housing inside wasnt secure, loose would be a term to describe them, then afer installing the bulb the chrome housing moved/shifted down and wont budge back up so its very off center
its the same way on both housings, the chrome piece inside that holds the bulb shifts freely and wont re-adjust back up
i know theres that 1 gold screw with the ring around it but it dosnt seem to be doing much, any-1 else have this problem or are there housings glued inside?
any helps/suggestions/info would be a nice
thanks in advance
Old 06-21-2006, 06:00 PM
MurdersV8s's Avatar
Default Re: aftermarket del sol headlight problems (digital sol)
stick with honda headlights. anything else doesn't fit right and come with future problems.. Go with one piece jdm del sol headlights. you know they are gonna fit and they have city lights in them
Old 06-21-2006, 06:09 PM
delslowhonda's Avatar
Default Re: aftermarket del sol headlight problems (MurdersV8s)
like the above guy said, and i doubt aftermarket lights are able to be baked and taken apart like the stock ones. that's the only way i could think of that you could possibly fix the problem. good luck with it man.
Old 06-22-2006, 04:42 AM
Default Re: aftermarket del sol headlight problems (delslowhonda)
eh, the quality of these aftermarket headlights is crap, from 5-10ft they look fine but up close if your an **** perfectionist like myself you see the imperfections in design and what-not
arg.....
guess ill just deal with it for now but now im definately going to do a hid retro in the next month or so and fix there problems and make them look perfect'
ChenLung
07-13-2010 10:32 PM
Rangedrecon
12-28-2008 08:41 PM
ds0440
Lighting
10-07-2007 04:39 PM
RusBear
07-17-2004 04:42 PM
JMod
10-31-2003 09:14 AM
Quick Reply: aftermarket del sol headlight problems
