AEM Hybrid Cold Air Intake
Need some help on the AEM Hybrid Cold Air Intake. I plan to get this intake for the 96-00 Civic. Will it fit a 99 Si? It was designed for a 96-00 Civic with a B-engine swap including that of a B18c5. I have a c5 intake manifold. This intake has a 3" diameter which I believe will give better flow compared to the intake made specifically for the Si which has a 2.5" diameter. The 99 Si has two connections going to the pipe(the valve cover breather and a intake sensor) at different locations. Question would be whether the Hybrid Intake has these 2 holes as well since it was made to fit on the 96-00 SOHC Civic with a B-series swap. I am not sure if the swap includes the sensor(not sure if SOHC has it).
Re: AEM Hybrid Cold Air Intake (garyc17)
SOHC does have the sensor. and i dont think the intake comes with them. im going to buy the same thing soon
im sure it would prob work, but dont they have two hybrids? one for a b16 and one for a b18? if so im sure it would be a lil different
Actually I was referring to the hole for the sensor. I am sure it will not include the sensor. It seems there is only one hole which is for the valve cover breather hose. Check this post: http://www.hondamarketplace.co...34793
Unless this intake is for a EG but it is stated in the post that it is for an EK.
Modified by garyc17 at 10:30 AM 5/8/2008
taimysho0
06-18-2009 06:20 PM
TypeRInNeed
12-28-2001 10:07 AM
