AEM cold air intake open hole. how to cover it up? PIC
Well i got a breather for my valve cover so i no longer need the little hose that runs fromt he intake to the valve cover but how do i plug this hole. shoul di just get another breather for it? I dotn want dirt and such going in. heres the hole i mean
Unceasing Measure
Re: AEM cold air intake open hole. how to cover it up? PIC (central_driver)
A.) why did you get that breather...?
B.) if you - for whatever reason - want to keep the gay breather, go ahead and take the tube that was on the intake, cut it, put a bolt in it and hose clamp or ziptie it in there. You could also look for a vacuum cap of the proper size, but it won't be simple to find one. A rubber stopper would be the ultimate solution.
Re: AEM cold air intake open hole. how to cover it up? PIC (Archidictus)
i think ive seen people with a plug that covers that hole but wanted to make sure or if i should just buy another valve breather for the intake or what.
the breather will not do anything for intake so i would just plug it with somthing to try and not draw more attencion to the intake than is needed
but what to plug it with. i no a breather wont do anything im just worried about the dirt and such going into the engine like that. i sware i have seen people with rubber plugs that fit perfect on the aem intakes but if i cant find that or am wrong about it. how would i plug it. best thing?
btw can someone also tell me how to get rid of that hose right next to the breather that connects to nothing...
Re: (central_driver)
you can run down to pepboys or whatever and find a vacuum nipple assortment. theres bound to be one that fits.
the other hose is a coolant hose you can remove the factory on and use a straight piece between the 2
Re: AEM cold air intake open hole. how to cover it up? PIC (jdmboi86)
go to pepboys or advance auto, get a vacuum cap and put it on, i don't know what that guy was talking about but when i used to do preformance work i had a ******* drawer full of them i got from advance auto
Re: AEM cold air intake open hole. how to cover it up? PIC (99blackcivicSi)
two words...duct tape
whatever you do, dont do what I did and wrap 33 black tape around the hole. THE INTAKE SUCKED IT IN. vacuum plug, or a rubber hose w/ a bolt a clamp can do. why'd you buy a breather anyway?
my aem intake came with both a hose and rubber plug to cover the hole up. i used the hose to connect the intake to the valve cover and tossed the plug
Re: (KoLRaNcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoLRaNcH »</TD></TR><TR><TD CLASS="quote">Just curious, does that breather actually do anything? </TD></TR></TABLE>
Nope. Worthless. Put the hose back on... It helps to vent pressure in the engine by vaccum. You might get crap all over your engine bay with that breather on too.
Re: AEM cold air intake open hole. how to cover it up? PIC (zero808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zero808 »</TD></TR><TR><TD CLASS="quote">two words...duct tape
whatever you do, dont do what I did and wrap 33 black tape around the hole. THE INTAKE SUCKED IT IN. vacuum plug, or a rubber hose w/ a bolt a clamp can do. why'd you buy a breather anyway? </TD></TR></TABLE>
One word... GHETTO. Seriously. Get a piece of hose and two clamps for about 3$ at autozone/pep boys/whatever, and put it on the way it was intended.
grammer nawzi
My intake came with little caps that go on those. You can get caps at any hardware store that would do the trick.
Re: AEM cold air intake open hole. how to cover it up? PIC (sicky)
PUt it the way it was intended. Pay attention to the way your car idles when you have it hooked up right and the way it was with the breather
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 »</TD></TR><TR><TD CLASS="quote">get another breater and put it on the intake</TD></TR></TABLE>
LOL
LOL
h4mza
11-22-2014 11:55 PM
