Rebuild ?'s
Old 10-16-2015, 06:38 AM
Fubar008's Avatar
Default Rebuild ?'s
I have a 00 Em1 with a JRSC. I bought the car over the summer needing some tlc. Over the winter I plan to do bodywork, suspension and some engine work. I have a few questions about the engine work. I have not done a comp test yet but it smokes and uses quite a bit of oil so rings for sure. Since it has a SC will a oem head gasket be ok? Anything I should beef up while I’m in there? I don’t have a huge budget so this will be as close to a stock rebuild as I can get but I also don’t want it to grenade because I cheaped out. I did notice the harmonic balance was wobbling pretty good. Could this just be the balancer? The previous owner gave me a rebuild kit for the SC so I plan on doing that too. Last question, how can I tell what psi pulley I’m running?
Thanks for any advice.
Old 10-16-2015, 07:59 AM
I'm not Rick!
rick_rabies's Avatar
Default Re: Rebuild ?'s
oem HG is fine.
PSI would depend on pully diameter
you would be amazed on the power picked up on from rebuilding motor/sc
ARP rod bolts and ARP head studs for sure.
Old 10-16-2015, 09:11 AM
I never narc'd on nobody!
NotARaCist's Avatar
Smoking isn't "rings for sure." It could be a few different things. You won't know without doing a leakdown test. There's nothing wrong with an OEM head gasket. If you actually want to rebuild it correctly, you'll end up boring .5 over, which means you'll need new pistons. Reassembling with re-used bearings is stupid, so there's something else for you to replace. You don't need ARP rod bolts unless you're planning on upping your rev limiter.
This is all simple stuff. Read some FAQ stickies.
Old 10-16-2015, 04:21 PM
joey1320's Avatar
I would highly recommend against driving the car with a wobbling harmonic balancer.
Old 10-16-2015, 04:24 PM
NotARaCist's Avatar
You uh...might want to try that again, joey. With full and complete sentences.
Old 10-16-2015, 04:25 PM
joey1320's Avatar
Lol
TekBuDDy
09-08-2010 01:18 PM
SHG_EasyE
01-15-2007 08:23 PM
Jowee
11-25-2005 03:49 PM
Jose-aka-Pedro
10-16-2005 04:34 PM
2-7offsuit
10-11-2005 09:23 AM
Quick Reply: Rebuild ?'s
