adjustable cam gears what are you running? b16a2
I have aem trutimes and im nowhere near a dyno right now so what are you guys running? thanks for all info. oh just in case. i have i/h/e and fpr.
Re: adjustable cam gears what are you running? b16a2 (civic-si-2000)
Just play around a little bit with them. Let the butt dyno see what settings work for your setup. Honestly it is pretty difficult to just go off someone elses cam timing as variations between the two setups can result in different gains from different settings.
Brian
Brian
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-si-2000 »</TD></TR><TR><TD CLASS="quote">I have aem trutimes and im nowhere near a dyno right now so what are you guys running? thanks for all info. oh just in case. i have i/h/e and fpr.</TD></TR></TABLE>
Every motor is different. Playing with the cam gears w/out a dyno can be dangerous, just a warning.
Re: adjustable cam gears what are you running? b16a2 (rodrez)
totally agree leave them at 0,0 until you get to a dyno or risk all the work you put into your engine.
