adding power steering
is this possible on a 93 cx hatch that came with none?
keep in mind im dropping in a 2000 gsr motor. how complicated and how much would this procedure cost. thanks
andy
andy
1 Post
Re: adding power steering (andyboy)
yes its possible did it on a 96 hatch the steps are nearly identical. http://repo.jackmoves.com/view...um119
I spent only about $100 on the whole thing.
Re: adding power steering (monicle)
You will need the whole subframe, the rack, pump, and some other stuff.
I am adding a power rack with a breather system. I think it should be fun.
1 Post
Re: adding power steering (White Lightnin)
you shouldnt need the subframe they are the same between all trim levels, just get the pump, resivoir, lines, rack, and the universal joint that connects the steering column and the rack.
nemesis25
10-31-2008 08:30 PM
