Adding passenger airbag?
Old 12-16-2003, 10:14 AM
White Lightnin's Avatar
Default Adding passenger airbag?
I have a 92 CX which of course did not come with an airbag. I am replacing the dash soon and the one I got came with the passenger side airbag. I was wondering if there is any way to activate it. Would be nice to give my girl the same protection I have
Old 12-16-2003, 10:27 AM
94 civic all mtr's Avatar
Default Re: Adding passenger airbag? (White Lightnin)
yeah just get the computer for the airbag and all the wires and then reset the srs unit
Old 12-16-2003, 10:54 AM
Thirty-Nine's Avatar
Default Re: Adding passenger airbag? (94 civic all mtr)
Yes, but aren't there sensors that'd be needed for correct operation?
Old 08-14-2005, 07:49 AM
T-RO's Avatar
Default Re: Adding passenger airbag? (Sushiboy)
Im bringing this back from the dead cause im now in the same position. I have a 92 CX (single airbag) and just got a dash with dual airbags.
I would like to have 2 airbags instead of 1. When searching the junkyard do i need ALL of the airbag wires or just the ones for the 2nd airbag? Where is the computer? Do i need a new airbag computer? Like what was mentioned above, are there additional sensors i need?
Old 08-14-2005, 10:03 AM
jz98ctr's Avatar
check it out
i just helped a buddy of mine gut the interior on his 93 bubbleback so i can build him a new dashboard and weld in a cage. i pulled just about everything for the srs system
1) there is obviously the airbags themselves
2) the srs unit normally found on the "tranny hump" just behind bottom of dash where the ashtray/lighter goes usually under a 2 piece black cover
3) i found 2 srs sensors (decelerometers if i am correct) in the vehicle, both in the front footwell area...under carpet, under foam insulation in a small pocket just about where the forewall meets the floorboards
you still have to make sure that your fuse box has the provisions for a plug and play operation.......hope this helps a little
Old 08-15-2005, 07:03 AM
T-RO's Avatar
It does help. Does anyone have some pics?
When i was just at the bone yard i found a piece of the srs unit (could tell cause of yellow cables). It was a silver round piece. Could this be one of the sensors?
Old 08-15-2005, 06:25 PM
B18EG6's Avatar
Default Re: (T-RO)
what dash did you get? one from a passenger dx or somethin?
Does anyone know if a teg passenger airbag will work on an eg dash, or vice a versa?
Old 08-15-2005, 07:48 PM
T-RO's Avatar
Yeah I got one from a DX Coupe
Old 08-18-2005, 05:28 AM
T-RO's Avatar
Hung_Lo
12
04-18-2009 02:36 AM
kjcrew_eg
07-01-2007 04:20 PM
littlegreenb18
10-03-2006 07:17 PM
navin
11-29-2004 04:47 PM
nwdave
05-25-2004 05:59 PM
Quick Reply: Adding passenger airbag?
