act clutch Q
act clutch Q
aright.. I need a new clutch... .. can yal help me pick one out... .. I wanted to get a act clutch but there is a lot of act styles clutchs and i've never bought a clutch before.. so can someone get me a website that sells them for a good price... what comes with the clutch and what do i need to get... i was searching the topics but didn't see anything helpful..
*93 civic ex
*95 z6 motor (60,000miles)
*greddy turbo & intercooler
*greddy turbo timer
*greddy fmu
*msd 6a ignition
*msd spark plug wires
*msd distributor cap
*msd blaster coil 3
*zex turbo/nos spark plugs
*b&m short shifter
*b&m fuel pressure regulator &gauge
*thermal tech heat wrap
*thermal turbo exhaust system
*pwr aluminum radiator
*red fal fan
*str fuel fail
*missing link map bypass valve
*blitz blow-off valve
*field boxer sfc vtec controller
*auto meter gauges (air/fuel, oil press., boost)
*93 civic ex
*greddy turbo timer
*greddy fmu
*msd 6a ignition
*msd blaster coil 3
*b&m short shifter
*red fal fan
*str fuel fail
Re: act clutch Q (bey)
ok- i have the act heavy duty pressure plate and the organic street disc for my car (same motor as you but no turbo). the clutch is rated hold something like 223 foot/pounds of torque, which is the equivilant of you pushing alot of boost. i think that it would be very well suited for your application. i got mine for around 320 dollars and it came with everything you'll need to install it.
ok.. so far i found a act heavy duty pressure plate clutch for $300 shiped from nippon power.com.. can anyone else tell me where i can buy it cheaper... thanks..
Re: (bey)
how much boost are you running? better yet how much torque are you making? do you plan to increase that any time soon?
if you're just making a typical amount of power, act hdss is probably all you need, and is a great clutch. 300 shipped is a pretty good price too. also consider the prolite flywheel also. it's a very capable, practical setup, and hella fun to drive.
Re: (jwn7)
http://www.clutchcityonline.co...c.htm
Might be a little high, but they show you how much the clutch supports up to
Re: act clutch Q (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">ok- i have the act heavy duty pressure plate and the organic street disc for my car (same motor as you but no turbo). the clutch is rated hold something like 223 foot/pounds of torque, which is the equivilant of you pushing alot of boost. i think that it would be very well suited for your application. i got mine for around 320 dollars and it came with everything you'll need to install it.</TD></TR></TABLE> What he said!
Thanks, good info. Any questions, just drop me an email.
