AC rejuvination
Old 12-08-2012, 12:10 PM
ozh_hawaiian's Avatar
Default AC rejuvination
I have a 93 eg8...My ac blows but not cold... I am trying to figure out the best route to get my ac back up and running... should I:
1. Take it to a shop first to have them check for leaks and seal up the system, then get a new compressor install it and have the shop charge it up...
2. Buy a new compressor, install it, and then take it to a shop and check for leaks and have them charge it...
Also should I get a r12 compressor and retrofit it, or get a r134 compressor and get the new lines to fit? and which lines if the r134?
mahalo
Old 12-08-2012, 02:21 PM
Kohen's Avatar
Default Re: AC rejuvination
It's possible it just has a leak and needs to be fixed and recharged. Unless you have a set of manifold gauges, just take it to a shop.
Why do you think your compressor is going out or is out?
You can't legally install an A/C compressor yourself. You couldn't even do it unless you had at least a set of manifold gauges or a recovery setup. If you vent your freeon to the atmosphere you could pay up to $25,000 in fees to the EPA.
Why would you get a r12 compressor and retrofit it? Get the compressor meant for the system.
Old 12-08-2012, 02:23 PM
Kohen's Avatar
One simple thing you could do is check your condenser and fan for obstruction and make sure they're working properly. Otherwise I'd just take it to a shop. If you're set on doing it yourself, have the shop recover the freeon and then you can safely and legally replace what you need to replace. But the A/C shop will have a leak detector to check for leaks.
Old 12-09-2012, 06:22 AM
Seagull Management
94EG8's Avatar
'92 - '93 Civics are R12.
OP what makes you think you need a compressor? It seems more like low freon than anything. Take it to a shop and have the system checked for leaks and have freon added if necessary.
le0ftw
09-01-2014 06:50 PM
210southstar
05-12-2009 09:44 AM
melsun_ap1
09-14-2007 06:59 PM
c1civic
05-01-2007 06:12 PM
Quick Reply: AC rejuvination
