AC panel light
AC panel light - Help Me Plz someone....
My Ac panel lights dont light, i bought a honda civic 96 model car a few days back and this is my first honda, last night i was in with a friend who has a 95 model Civic and his Ac buttons and the heat and cold indicator panel was lite, but on mine it didnt light, is it possible if my bulb would have gone fuse as this was the case on my automatic gear selector light and i changed the bulb, but how about the A/C panel. Can someone also please tell me if i want to check, how do i go about it, the fuses are all perfect so i suspect if there is a bulb, probably it might have been fused.... any advice on checking it..
Modified by dj_factor at 2:24 AM 3/7/2007
you can ethier check your fuse, need new light bulbs because your is bad, hit it a few time to see if it will come on, or the wiring in the back is loose
Re: (J.D.M_Junk)
Thanks JDM Junk . All the fuses are perfectly fine as i was checking this morning again, i guess the bulb might have blown off, its an 11 year old car so such things are possible, can you please tell me if i want to reach to the bulbs on the AC Panel (The Cold and Hot air selector + the 1,2,3,4 speed selector) how do i go about it, where should i open the screws and other stuff. Any tricky part...
Cheers or the help..
Allgetshere
Honda CR-V & Element
07-14-2016 05:54 PM
Hondatypr636
17
06-26-2014 09:24 AM
dj_factor
03-07-2007 12:34 PM
DJ_CARY
04-02-2005 07:46 PM
