AC mode actuator motor stucks
Old 06-01-2019, 02:49 AM
Default AC mode actuator motor stucks
Hi
I am having issue that the first 2 mode works correctly and then after that it got stuck and the motor starts clicking. I don't think motor is the issue as it is working. So what can be the issue?
It stuck at this position
Car is civic 2000 pkdm
Hasan Khurshid is offline
Old 06-01-2019, 04:48 AM
Default Re: AC mode actuator motor stucks
This is usually stripped gears in the motor. Detach the link pushrod from the motor and check that the mechanism in the air box moves freely. You can also use this to set the mode you want until you get a new motor.
mk378 is offline
Old 06-01-2019, 05:19 AM
Be careful that area where it slides will cut your finger like no other. It's sharp.
stin1 is offline
Old 06-01-2019, 05:53 AM
For detaching push rod I only need to remove the bolt on the motor?
Old 06-01-2019, 05:55 AM
Thanks for the precaution
  • Ask a Question
Question Title:
Description:
