AC Compressor Bracket
What AC Bracket can I use for my eg? It will have a B18C1 (94-95) swap in it. I am going to use my old compressor from the civic. I've heard I can only use the del sol ac bracket, but I've also heard I can use any b-series bracket? So which one is it. Thanks for anyones help.
Re: AC Compressor Bracket (t88)
P54 I believe...
you need this one.
http://cgi.ebay.com/ebaymotors...%3AIT I already sold that one. I do have another exact same one, but, the belt temsioner broke off of it............So, you can use it, but you wont have AC. $50 shipped. |
Re: AC Compressor Bracket (spidermancivic)
That one won't work for an EG to the best of my knowledge..
Re: AC Compressor Bracket (ERA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ERA »</TD></TR><TR><TD CLASS="quote">That one won't work for an EG to the best of my knowledge..</TD></TR></TABLE>
Not only that, but that one in the ebay ad has a bolt broken off inside the bottom right hole. |
I have an ac bracket from my b18c spec r...email me vernon_brandon@hotmail.com...maybe we can work a fair trade or something. https://honda-tech.com/forums/images/smilies/emthup.gif
you can use a jdm type R bracket also. i am selling one. let me know if you want it.
Re: AC Compressor Bracket (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">
Not only that, but that one in the ebay ad has a bolt broken off inside the bottom right hole.</TD></TR></TABLE> Thats actually a shipping peanut stuck in the hole. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ERA »</TD></TR><TR><TD CLASS="quote">That one won't work for an EG to the best of my knowledge..</TD></TR></TABLE> I believe it does, but cant confirm until I check my cousins eg gsr hatch. Basically, the differences in the AC brackets for B series is that one has an xtra mount that serves as an engine mount and the other doesnt....................correct? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spidermancivic »</TD></TR><TR><TD CLASS="quote">
Thats actually a shipping peanut stuck in the hole. I believe it does, but cant confirm until I check my cousins eg gsr hatch. Basically, the differences in the AC brackets for B series is that one has an xtra mount that serves as an engine mount and the other doesnt....................correct? </TD></TR></TABLE> The mounting holes for the compressor are different, as well as it's placement in relation to the hoses. The only one I have used with the 92-95 compressor is the P54, I know for a fact the P30 won't work, but the 99-00 might be a different story. |
i've got the p54 on my b18c and the motor is in my 95 dx the bracket you need is p54, off a del-sol vtec
Re: AC Compressor Bracket (siblueg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblueg »</TD></TR><TR><TD CLASS="quote">i've got the p54 on my b18c and the motor is in my 95 dx the bracket you need is p54, off a del-sol vtec </TD></TR></TABLE>
or you can use the integra type R bracket that i have, use the ac compressor that i have, and just buy the del sol hoses to connect from the compressor to the tubes in your car. my friend has this setup, so i know it works. let me know if you want to buy both from me. i will work a nice package deal with you. jante@stevens.edu |
Not only that, but that one in the ebay ad has a bolt broken off inside the bottom right hole.</TD></TR></TABLE> Good Eye... yeah, del sol bracket, I don't know about the type R bracket in an EG, I don't think so though. |
Re: AC Compressor Bracket (JinDIESEL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinDIESEL »</TD></TR><TR><TD CLASS="quote">
or you can use the integra type R bracket that i have, use the ac compressor that i have, and just buy the del sol hoses to connect from the compressor to the tubes in your car. my friend has this setup, so i know it works. let me know if you want to buy both from me. i will work a nice package deal with you. jante@stevens.edu</TD></TR></TABLE> why would he buy 2 things if he only needed 1, all of his stock hoses will fit with p54 del-sol bracket anyways. got mine for 112.98 shipped brand new from honda too |
if you're wanting to use your 'old' compressor, which I'm assuming means your d series compressor on your b18 block, you can either use a del sol p54-that's what I did- or a crv p7h...both will work....as for those other compressors I'm not sure if they will work on a d series a/c comp to b series block or not......
OK, the AC bracket on my cousins 92 hatch DX with a 94 USDM integra GSR motor says P72.....
Maybe theres more than one bracket that will work https://honda-tech.com/forums/images/smilies/emwink.gif Hey, but you want to use your civic compressor. So it wont work. Not on this bracket that is. [QUOTE=t88]The mounting holes for the compressor are different, as well as it's placement in relation to the hoses. The only one I have used with the 92-95 compressor is the P54, I know for a fact the P30 won't work, but the 99-00 might be a different story. QUOTE] Of course the compressor wont bolt up. Maybe I typed something wrong. The bracket however will bolt up. |
OK, I got it. Thanks for the help everyone! Now it's time to go get some AC! Too damn hot not to have one, but fall's coming up so it won't be too bad!
Back from the dead http://images.honda-tech.com/set1//smile/emcrook.gif
I have a 00 jdm itr a/c bracket and a JDM D15B a/c compressor, the 2 DO NOT FIT, a/c b olts dont line up https://honda-tech.com/forums/images...s/emthdown.gif I have just picked up a P30 and P72 A/c bracket and they look identical, but will either work? Shame as the ITR one is cast ally and a fair bit lighter than the cast steel P30/p72 brackets https://honda-tech.com/forums/images...s/emsmilep.gif Going to the shop tomorrow to checki so will report back but would like to know in advance, save a wasted 200mile round trip eddy |
