ABS problem... i need your help
Old 07-13-2005, 05:47 PM
EeeJayEight's Avatar
Default ABS problem... i need your help
i took my car to the shop and hooked up a scanner to read the abs code... problem is that there are not codes being stored and when i jumper the plug the abs light does not flash like it is supposed to.
well, the light came on all the sudden with no relation to hard braking or anything. I just started my car up one day and all the sudden ABS light. However, i did install some fog lights but they are wired using that one pin connected that is down by the fuse box and then a switch... no OEM harness... i was wondering if maybe i could have hit something down there?? are there ABS wires in that area?
Any ideas...OTHER THAN DISCONNECTING THE LIGHT...???
Old 07-13-2005, 06:10 PM
Vero's Avatar
you could of hit something down there, ABS does run through it.
Old 07-13-2005, 06:22 PM
Default Re: (Vero)
already figured it out...problem was that the fuse was missing..
sounds dumb but heres the deal, it was the defroster fuse that i pulled since my rear defroster doesnt work due to tint stripping... i never knew that ABS and defrost used that same fuse... anyways thanks for the help
Incognito
07-14-2017 11:02 PM
Huntersdc4
11-21-2014 05:43 AM
Turbo Dan
08-15-2010 02:59 PM
Whatislove
Honda Civic (2001 - 2005)
08-29-2009 08:35 PM
vti444
09-06-2004 12:44 PM
Quick Reply: ABS problem... i need your help
