abs/ non-abs question?
ok, i have a 1997 dx civic with a b16a engine and ecu. Right now i don't have abs... i believe that this is because 1997DXs dont have abs (correct?).
I have found an integra (1994-2001) {not GSR}. I want to swap the front and rear brakes... i have searched honda tech and believe that this should be pretty simple.
My questions are about the abs that the integra has. When i swap all 4 brakes, the MC and the prop. valve, is the abs going to be a problem?
i also would like to use the sway bars... is that possible/how hard?
Re: abs/ non-abs question? (Nfire247)
I dont think the abs will be a problem. As for the sway bar info, try a search b/c their has been a few threads lately on what you need to use the sway bars (lower control arms, and ect).
