99 Si vs 96 Hatch in pricing
Guest
Posts: n/a
Please move this thread if this is not the place for this.
I just need some advice on a trade and what can be done to make it fair on both ends.
Both cars have perfect titles.
both cars do not have A/C P/S or C/C.
99 Civic Si rolling shell 73,xxx miles
EXTERIOR:
99 Si shell
Fresh Milano Red R81 paint job from head to toe less than 4k miles
15'' Konig Heliums in bronze /w Falken Azenis with less than 1k miles
Skunk 2 lugs in bronze
CTR headlamps /w working city lights
OEM front lip, side skirt, rear lip, and spoiler
Si emblem on front grill
JDMShit.com CF hood /w pins
OEM fogs
Brembo drilled rotors on every corner /w Axis MM pads
SUSPENSION:
Comtech front upper bar
Tein SS coils
DC Sports rear lower tie in polish
ENGINE:
Place Racing driver's motor mount
Urathane front toruqe mounts
Rear Energy Suspension's rear inserts.
NGK Wires
MaxRev log manifold /w 35mm/38mm flanged WG (for B) and MaxRev 2.5 DP
2.5 JDM test pipe /w 2.5 side dump
Tial Gate in polished /w custom straight vertical dump
Greddy Type24 FMIC
Greddy S valve
Greddy polished IC pipes
Greddy oil catch can
Bored ITR T-body
Skunk2 IM for Pr3 heads
Walbro 255-hi pump
DSM 450 blue top injectors
AEM fuel rail in red /w B&M FPR and water gauge adapted
CTR crank pulley
DC Sports SS exhaust
DC Sports short shifter
OBD2-OBD1 conversion harness
B16 stock tranny (no grinds) /w ACT 2600psi clutch kit and JUN UL flywheel
Spoon Sports drain plugs
INTERIOR:
Spoon Sports ****
CTR shift boot
Kenwood deck 50x4
APexi Rev-Speed Meter
Dual full pillar pods /w Phantom A/F and Boost gauges
Sparco Speed seats in red /w Sparco 4pt bolt-in harnesses
96 Civic DX 170,xxx miles
INTERIOR:
SI cluster
99 dark grey leather gsr seats
ALPINE CDA-9835 Deck
Infinity Reference components
PowerBase Extreme Coaxials
also have a 12" Eclipse Sub that i'll throw in
GSR shift ****
EXTERIOR:
99-00 SI front end
Si font lip/side skirts
CTR headlights
new 16" slipstrems, gunmetal w/polished lip on fuzion tires
on tokico adjustable as tein type s springs
vis spool carbon fiber spoiler
spoon carbon fiber mirrors
just painted type r black, inside and out
MOTOR:
95 usdm gsr motor (has about 90k on it)
95 GSR tranny /w 3rd gear grind
crane stage 2 cams
str gears
stock block
greddy header
apexi n1 cat-back
custom chipped uberdata p28 untuned
hasport drivers side motor mount
Walbro 255-hi pump
skunk2 odb2-odb1 harness
ngk wires
comp stage 1 clutch
EXTERIOR:
99 Si shell
OEM fogs
SUSPENSION:
Tein SS coils
ENGINE:
NGK Wires
Greddy Type24 FMIC
Greddy S valve
Bored ITR T-body
Walbro 255-hi pump
CTR crank pulley
INTERIOR:
Spoon Sports ****
CTR shift boot
Kenwood deck 50x4
INTERIOR:
SI cluster
GSR shift ****
EXTERIOR:
99-00 SI front end
CTR headlights
MOTOR:
crane stage 2 cams
str gears
stock block
greddy header
apexi n1 cat-back
Walbro 255-hi pump
ngk wires
comp stage 1 clutch
Guest
Posts: n/a
Re: 99 Si vs 96 Hatch in pricing (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">so whats going on your gonna trade witch one is yours anywase i dont think this belongs here.</TD></TR></TABLE>
Probably not, but this is forum where most people with Civics rest, and hatches with swaps range on a HUGE spectrum, and obviously I don't know well enough, thought I'd ask.
And the Si is mine, however, it really shouldn't matter who has what. Is this trade even, should cash be invovled, and how much?
Guest
Posts: n/a
Re: (papito_85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papito_85 »</TD></TR><TR><TD CLASS="quote">i would stay with the si, but if you are going to trade it, it would be an even trade in my eyes, mainly cause the si is just a shell.</TD></TR></TABLE>
I wish I could to, but I can't.
The reason why I am asking here is cause I see swapped hatches range from 6-8 with nearly the same mods and chasis.
Re: 99 Si vs 96 Hatch in pricing (Louie_EM1)
honestly you have to look at it just as honda does,
Coupes are more desireable to the public, and the fact that the Hatch is at best a 14sec car on street tires..and your car easily does 13s with the turbo setup. the coupe would sell on the open market for $13k tops.. and I mean top if you reinstall the interior.. the hatch would sell for $8k at most given that the motor is older and the tranny need to be rebuilt.. but who cares, it seems as though you decision that the coupe is worth more in your head.
So ask the guy for 4k or more and trade,you can get a itr tranny to wake up that motor and get a decent suspension over the tokicos..and call it a day... of course the only people who would pay so much for these cars are kids who dont have the resources or passion to build the car themselves. To most H-Ters the hatch is worth what 7k and the si shell is 10k.. hope this helps if not oh wel in reflection, I would keep the coupe or sell it and get a different car
Guest
Posts: n/a
Re: 99 Si vs 96 Hatch in pricing (IM ALL BOB)
The interior on the Si is all there.
And yea, I do feel my coupe is worth a bit more, but I don't think 10k is right since it is just a shell, plus I am still missing a few turbo parts, tuning ect.. to make it up to that 13k mark that it might/could be worth depending on the build.
If the hatch right now sitting as is is about 8k then I think it's pretty close to an even trade. I have been trying to sell my car for ~8k for a while with no luck. (I see my car for about 2 weeks a year which is why I cannot finish her )
Well I can just wish you luck on getting the max you canfor the coupe, but if you are really wanting a hatch, then go for it, especially if the paint is new and such, it'll make a good project since it looks to be in flawless condition. But always beware of other peoples projects as it may have problems which you can not see until you have the car for a while. I say keep the Coupe. But as you said you have no time for a car. its hard to say what you should do. Just make sure you have no doubts about the trade, if you do forget it.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IM ALL BOB »</TD></TR><TR><TD CLASS="quote">Just make sure you have no doubts about the trade, if you do forget it. </TD></TR></TABLE>
That's all I'm praying for thanks.
I offered him the Si minus the FMIC for his car I hope that's a good deal since he has to haul her away, he doesn't live too far.
Re: 99 Si vs 96 Hatch in pricing (Luserkid)
EK-9 much cleaner i think cuz i have one.trust me there hella better. SI 's are clean dont get me wrong. but i would get the hatchy.
I'd just finish your car. Here's the bottom line yours has 73,000 some miles and the hatch has 170,000 some. Regardless of engine/tranny the chassis has those many miles. Besides your car is worth a lot more than the hatch ever will be. IMO I wouldn't do it.
kaliparts
01-23-2009 01:33 AM
ant$missShift
08-16-2007 05:12 PM
