99 si/b18c swap - Three cel codes
my 99 si 18c swap is throwing some codes. the 1st one is the cat becuase im running a test pipe n no cat. the second one is for the primary o2 sensor. n the thrid is for the car running rich or lean. would running a test pipe n no cat cuase this? and my idol jumps from 800 to bout 1500 when starting and then it settles down but sometimes dropping to like 200 or 300 sounding like its gonna stall but never does the idol just picks back up?????
Re: 99si b18c swap cel
codes 45, 61, and 67. so try replacing the first o2 sensor and putting a cat on ? the test pipe is from the previous owner. im trying to fix all his mistakes. n yes im new to the honda game so im still learning.
Re: 99 si/b18c swap - Three cel codes
I believe that you need to install an ECU for the B18, but have the swap experts verify this.
you can run a mechanical cheat for your secondary o2 sensor to get it to think there is a cat there. There is a thread here somewhere that tells you what to do
Found this on here http://hondamarketplace.com/showthread.php?t=2447783
