99 ex auto to manual questions
ok i am doing a auto to manual conversion on my girls 99 ex
i got some write ups for it but i still have some ????.
it says for autos that the iacv is differnt then the manual one and to do this swap you have to get a intake manifold off a 5speed civic and also a iacv and the plug off a 5speed civic.
so my question is
is there any way around getting a plug for the 5speed iacv cant i just convert the auto plug to work with the 5speed iacv
so my question is
Re: 99 ex auto to manual questions (THEROPE)
They are mounted differently in different locations. The units themselves also work differently. The 3wire iacv which you have is located on the underside of the throttle body. The 2wire iacv you need is located on the backside of the intake manifold.
Re: 99 ex auto to manual questions (wadup)
thank you i understand all of that
thats not the question
again can i make the auto plug just the plug work on the 5speed unit???
I gotta link to rewiring it... holdup lemme look. Oh and no the 3-wire IACV plug will NOT work... All you'll need is the 2-wire IACV plug.
Re: 99 ex auto to manual questions (Civic4less)
ok i got that part already but the problem is i dont have a 2 pin connector
SO BACK TO THE QUESTION IS THERE A WAY TO CONVERT THE 3 PIN PLUG ON THE AUTO'S TO A 2 PIN PLUG NEEDED FOR THE MANUAL'S??? PLEASE ANYONE. AND AGAIN I DONT HAVE A 5SPEED PLUG.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEROPE »</TD></TR><TR><TD CLASS="quote">ok i got that part already but the problem is i dont have a 2 pin connector
SO BACK TO THE QUESTION IS THERE A WAY TO CONVERT THE 3 PIN PLUG ON THE AUTO'S TO A 2 PIN PLUG NEEDED FOR THE MANUAL'S??? PLEASE ANYONE. AND AGAIN I DONT HAVE A 5SPEED PLUG.</TD></TR></TABLE>
Dude... all you have to do is go to a junkyard... snip one off with about 10 inches of wire and walk out. Even if you want to pay for it I doubt it'll be more then 10$ . I'm a broke *** 16 year old and even I can afford that.
BTW heres the link. http://www.ff-squad.com/tech/w...8.jpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic4less »</TD></TR><TR><TD CLASS="quote">
BTW heres the link. http://www.ff-squad.com/tech/w...8.jpg</TD></TR></TABLE>
that was the answer i was looking for thank you
ok another question
what mounts do i need for the swap
its for a 99civic ex coupe
i think it says i just need the trans mount but isnt there two trans mounts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEROPE »</TD></TR><TR><TD CLASS="quote">ok another question
i think it says i just need the trans mount but isnt there two trans mounts?</TD></TR></TABLE>
You won't need different mounts I'm told, everything will bolt right up. I have a 00 EX and I'll be doing the same swap soon.
I'm pretty sure the trans mounts are different. So all you'll need are those. I think any out of a 96-00 will work.
Btw... No Prob.
Btw... No Prob.
Will you make something up for me please?
If I remember correctly from doing a H22 5-speed swap into an auto EX, it was just like doing a swap in an Integra.
The only mount that's different is the upper transmission mount. Back when I did them, they didn't have any aftermarket mounts available. Now I believe HASport has them. You can either purchase those, fabricate your own, or reweld the mount bracket on the chassis slightly forward to where the 5-speed bracket would be on a 5-speed car.
Note the brackets are the same, it's just slightly more forward in the chassis of a 5-speed car.
burnoutboy
07-01-2014 04:32 AM
Killercocopuff
10-17-2011 07:55 AM
Mikes2000civicsi
02-24-2010 11:56 AM
