99 ek with obd2 motor and 0bd1 ecu
Got ECU wired up w/ new wiring harness and car starts and runs.
Idle surges, but could be a number of issues causing that......
No O2 sensor hooked up, vacuum leaks, etc.
I want to add a digital temp guage, and the kit came with a new water temp sensor, with 2 wires (ground and +guage). Original sensor has only one wire hook up.
Will the car run fine without the temp sensor hooked up to the harness?
Then I can hook up the new guage by itself to the sensor.
Or should I splice the harness to the new sensor w/ the temp gage wiring?
Just wondering if one of the idle issues is from the temp guage not being hooked up.
Re: 99 ek with obd2 motor and 0bd1 ecu
Ok, what I do I my turbo ls/vtec:
https://honda-tech.com/attachment.ph...1&d=1396918232
Remove and cut the nipple ( Yellow square), let a tiny portion to weld a coupling. Then screw it back and the sensor in the new coupling.
You can try and find a female adapter that screw there, but this thread is a b****.
something like this, but I made mine with the stock thread.
https://encrypted-tbn3.gstatic.com/i...hhI68nW6n63z6y
CptHMCrunch
09-01-2014 01:56 AM
