99 civic si swap
99 civic si swap
I bought a 99 civic si and pooched the engine. I got a JDM VTECH D16AY7 engine and tranny cheap that I want to throw in since this will be a winter car for my skyline. Just wondering what else I will need. Are the ecus the same? I'm hoping I can just drop the engine out and stick this one in.
can someone help me out ASAP please
The Grumpiest
Re: 99 civic si swap
D16A
- Found in:
- 1997-1999 JDM Domani (MB4) [1]
- Bore and Stroke :75,0×90 mm
- Displacement : 1,590 cc (97 cu in)
- Compression : 9.3:1
- Power : 120 PS (88 kW; 118 hp) at 6,400 rpm
- Torque: 144 Nm
- Redline : 7,000 rpm
- Valvetrain : SOHC (4 valves per cylinder)
- Fuel Control : OBD2a
- ECU Code: PBB-J61
- Special note : this engine come with single VTEC solenoid and an EGR valve but it does not have an actual VTEC (high cam mode).
- This is Wikipedia info so very all of it. Especially the special note.
From what I can see its the same as the usdm d16z6 I don't care what it takes to swap I will do it so I bought it cause it was cheap. So now I'm just wondering what exactly it will require to swap because if it comes with the ecu it will most likely be RHD if it doesn't I need to know what one to pick up at the local wreckers
The Grumpiest
I have a JDM engine in my hatch. There was no "converting" from LHD to RHD. I don't think engines are RHD. And I don't think you're getting the ECU with it. And this is OBD2a so it can't be similar to a Z6 otehr wise I would have said to use a P28.
The Grumpiest
Call your engine people. That's what we did. If they're worth their salt they should be able to answer your questions. I'm not finding much on this engine. or even this swap in general.
http://www.ej8squad.com/archive/inde...read-5805.html
Says here it will run but run rich. I'll talk to my engine guys see what they say.
The Grumpiest
JBriggz07
03-18-2008 05:12 AM
