99 civic si spring & shocks into 93 del sol si?
would a set of springs and shocks, both front and rear, came out of a 99 or 00 civic si would fit into a 93 del sol si? and would it lower or raise the car a bit?
thanks
thanks
Re: 99 civic si spring & shocks into 93 del sol si? (jdmsol)
what are my options as to replacing my springs and shocks...........not so expensive, my stock ones are diying and i need to replace them, and i can feel almost every single bumps on the road now.
Re: 99 civic si spring & shocks into 93 del sol si? (intezn)
How much are you working with? Do you want stock or aftermarket? Just the other day someone was trying to sell stock springs in this forum. I've got Intrax sport springs (2 inch drop) and I absolutely love them.
how much........not too much like around 100 either stock or aftermarket...
are my shocks gone or what is wrong? when i go over any kind of bumps......i can feel the car shaking moving left to right....
[Modified by intezn, 8:29 PM 10/20/2002]
Hard to tell without pulling the shocks out and checking them out. I'm sure you could get the stock springs off that guy for well under 100 bucks. My Intrax ran me like 170 shipped or something. This was also quite some time ago, so I'm sure they are lower in price now. I'm going to find the thread on the springs and bump it for you.
so you think replacing my springs would fix my problem? i am really thinking is the shocks.
thanks for finding the other thread for me
thanks for ur help, i could only edit this to replay, my limit has reached for today.
[Modified by intezn, 8:45 PM 10/20/2002]
i'm pretty sure it will work.....Most Civic parts are interchangeable w/ each other...the only thing is that w/ the Si Springs your car will sit a lil higher since the spring rate is built for the weight of the Si...The shocks will also be interchangeabe....right now i'm using some Ek springs on my Eg...works fine and looks nice...
Re: 99 civic si spring & shocks into 93 del sol si? (Eg6xCiViC)
YES the springs will work, but the 00 si rear shocks will not fit.
Re: 99 civic si spring & shocks into 93 del sol si? (zzZZzzleeperCX)
ok, what other shocks would work then? or how much am i looking at if i am getting gc and tokico
i think its the shocks, is your lowered and if it is how long has it been lowered? just get agx kybs.
if you want cheap shocks, go to a junkyard and get one from a 94+ integra
[Modified by zzZZzzleeperCX, 8:09 AM 10/22/2002]
stock for both front and rear, i only added 2 struct bar so far, 1 under hood and 1 in trunk.
Yes, the 99-00 Civic Si springs/shocks WILL bolt into a 93 del Sol, but you need the del Sol lower suspension fork too.....the Civic LCA is wider than the del Sol one, so you have to swap them around. Same is true for the upper A arm.
It will raise you car a little - at least it did mine, but that MAY just have been the fact that the tired old del Sol components were plain worn out.
HTH!
Steve
HTH!
Steve
nautica_t
02-07-2006 01:08 PM
ianae86
18
12-05-2005 03:26 PM
drunkenmonkey
07-02-2002 12:37 PM
