99 civic si fluctuating idle and random misfires
My friend just got a burnt exhaust valve replaced along with valve job. It was running great after i put it together but three months later it started to misfire. He took it to the shop n they fried his dizzy while performing a compression test. Compression was 180 across. Bought a new dizzy and it starts but its fluctuating at idle. I would get misfires from 1-4 and random misfiring code. It had a code for the IACV so i cleaned it out n the code is gone but its still idling bad. The engine drives great n has plenty of power but when u let the rpm down then the idle problem starts. The exhaust is smoking a little blue n oil needs to be put in once in a while.He also mentioned the coolant burns off as well but like i said the compression is good. Has anyone encountered this problem? I'm running out of ideas.
Re: 99 civic si fluctuating idle and random misfires
Yes everything is stock except intake,headers,exhaust. Codes will start with p0301 and then p0302,p0303,p0304 n p1399 after driving it down the street but it doesnt feel like its misfiring. nice response when wanted.
current dizzy is brand new but not aftermarket though i suspected it might be that but havent ran any tests yet
Aftermarket distributors are often problematic.
Also measure the fuel pressure.
How loose? Out of spec loose?
too loose of a valve adjustment will cause such misfires?
it ticks a little bit after i adjusted them so im jus saying its a little loose thats all. it was too tight before n it idle low n rough.
I had this problem too I had cams put in and the ticking were my valves being wayyy to loose sounded like a sewing machine. I had them adjusted correctly and now it's nice and quiet.
I still do at times when i first start the engine it will throw a light right away, But after i clear the light and drive it, it's fine. I've also been getting this P0505 idle malfunction code that i can't seem to get rid of too.
dchampn
40
02-11-2013 02:36 PM
TwistedSI
14
06-20-2004 04:24 AM
