99' Civic SI dome light wire?
Where the $*%& is this wire?! I read this:
DOMELIGHT LT.GRN/RED (-) ALARM PLUG RT OF STEER COLUMN
but that doesnt help, there is one plug right of the steering column and it doesn't have a green and red wire coming out of it. Anyone know? I'd test but I dont have anything to test with.
Re: 99' Civic SI dome light wire? (funkylemons)
Get it in the kickpanel, much easier. It is however in a plug to the left of the steering column. Pop off your kick panel and you will find it in the harness running to the rear.
HTH
Miguel
HTH
Miguel
Re: 99' Civic SI dome light wire? (SIINSI)
Ok, cool, I already had a wire ran to the steering column, so I'll tap the one there. I saw that one to the left but a friend said "IT'S ON THE RIGHT!" and without testing I wanted to be sure before I started tapping wires, http://www.bulldogsecurity.com for incorrect wiring diagrams for cars i guess...
there is wire harness with a green plug probably with a little piece of blue tape around it below and to the right of the steering column, the wire is GREEN with a RED STRIPE, there should only be one wire on that harness with that color. I belive if you're looking for it the wire directly next to the dome wire is the wire that catches the trunk, its been a long time but i think its GREEN with a BLACK stripe and is also a negative trigger.
[Modified by The AntiRice, 7:35 PM 3/22/2002]
jermo
Acura TSX
02-25-2017 08:01 PM
