99 civic dx: overheating
Hello. Looking for some help. I've replaced my waterpump, thermostat, hoses,sensors, and cap. I had the radiator flushed and inspected. Had a compression test done to check for bad head gasket. Everything checks out good. Car still gets scary hot when I have to stop after driving for even 30 minutes. No air in system. Got fan switch wired to run constantly. Still no difference. I'm stumped. Any suggestions?
Re: 99 civic dx: overheating
If there's anyone who might have some ideas I would be forever grateful. I'm a decent mechanic but haven't ever had this much trouble diagnosing the problem.
Which thermostat did you get? Some ppl have had issues with aftermarket oem replacement ones getting stuck close which is why they recommend getting the Honda OEM replacement from the dealer. Also you have you tried running the car with no thermostat?
Don't remember what the numbers were. Guy said they were good. What about the metal line that runs across the back side of the engine? Could that be clogged possibly?
If. you confirm a blown head gasket with block tester then do a cylinders compression test. If, you're getting good compression then maybe it's worth doing a head gasket replacement. If, the compression is bad in one or more cylinders at the mileage on that engine..best to replace engine.
Thanks. I will test it later this week and report back. I appreciate all the advice from everyone. Just need it to get me to work a couple more days and then I can rip it apart if necessary
you'd be better off diagnosing the real problem before just driving it to work. you said there was no air in system, did you burp it? if your coolant isnt flowing properly and you are overheating you run the risk of blowing the head gasket. if you replaced anything that opened the cooling system (which you did) you need to burp it. also i would take out the thermostat and heat it in water and watch to see if it opens. lines could be clogged if some type of no-leak **** was used in the coolant, but other than that im not sure. also wiring the cooling fan to run constantly isnt good either and isnt going to make your coolant flow. and it wont cool down the car enough to keep your head gasket from blowing. i know because ive experienced that. guy i bought my civic off of had it wired to a toggle switch..... and i bought this before i really knew how to really do any maintenance, im still learning, but needless to say i ended up having to replace my head gasket. but now im rambling lol i apologize XD
jakeman
03-12-2013 08:38 AM
imanaznpanda
07-26-2006 10:41 PM
SRd240sx
11-21-2005 12:07 PM
