99 automatic civic wont go into gear
Old 07-28-2011, 07:34 AM
zacheryleatherw's Avatar
Default 99 automatic civic wont go into gear
K I was driving my car last night and out of no where while I was pulling off from a light. When I was waiting for someone to tow me I put it in drive and it moved but by the time I took the tow strap off it wasn't working again?!?
Old 07-28-2011, 08:55 AM
Former User's Avatar
Default Re: 99 automatic civic wont go into gear
ATF level full? Old ATF? CEL codes? D4 light blinking?
Old 07-28-2011, 09:38 AM
No codes, has plenty of fluid, and by looking the axles are still in th tranny.
Old 07-28-2011, 09:45 AM
Try a few ATF drain & refill cycles and then go from there. Otherwise, you should be able to pick up a replacement auto tranny for a decent price. There's much higher demand for manual trannies.
Old 07-28-2011, 10:02 AM
Wrona's Avatar
also check ur cable i know it is probably not it but worth a tr and Ron dude here in colorado auto trannies are going for like 300+ one guy is selling one 550 they are insane ls swaps are going for 300 its redicilous
Old 07-28-2011, 10:10 AM
Originally Posted by Wrona
...and Ron dude here in colorado auto trannies are going for like 300+ one guy is selling one 550 they are insane ls swaps are going for 300 its redicilous
That's crazy. I guess you've got to shop around. People doing auto to manual swaps would likely let their auto transmissions go for a more reasonable price.
Old 07-28-2011, 10:17 AM
Ya I lookled under it and there's a bent heat shield by where the cable goes in the tranny. All it does is rev up like its stuck in nutruel.
Old 07-28-2011, 10:20 AM
Wrona's Avatar
im doing that swap myself at the moment just kind of low on funds so i am parting parts slowly from local junkyards
also is the heatshield actually forcing the cable to be under pressure? like does it restrict movement? if it does remove it or bend it back and see if it helps
Old 07-28-2011, 12:09 PM
How much would it cost for everything to swap it over to a standard? Also I checked the fluid and it has too much
Old 07-28-2011, 03:18 PM
Wrona's Avatar
well so far i bought pedals 30 bucks from pull and pay 5 bucks for master cylinder with resirvore got prebent lines for like 2 bucks shift linkage i got for free from a friend now the tranny is going to be like 50-200 bucks cause im lokoing for a EX tranny
Old 07-28-2011, 03:22 PM
There's also a faint I humming noise when it doesn't engage and it wants to drive after sitting for a bit
Old 07-28-2011, 07:28 PM
This is really starting to **** me off! When I don't let it run for a bit it goes but if I stop its like it pops out of gear any help please??? Can I take the tranny out without taking me motor out?
Old 07-29-2011, 03:05 AM
cheggie's Avatar
You can remove the transmission with the engine in. If the automatic is toast, there are used replacements or rebuilt units. Swapping to a manual is going to be several days work in a shop, after you've gathered all the parts. Trans, pedals, shifter and linkage, clutch slave, master and lines, starter, flywheel, new clutch, mounts. If you really want it like a factory 5 speed car, pcm, intake, shifter boot and gauge cluster too. Just for starters. I did it, it's very satisfying. I had another vehicle to drive while I was performing the swap. I really love the Civic with a stick shift. I think the parts for the swap totalled around $700, but I did "everything" - new clutch, slave and master, resurface flywheel, new isb for the trans, new rear main seal while I was in there, etc. Also, I didn't charge myself any labor. I got most of the stuff from a kid who was parting a car out, which was cheap, but spent a lot of the swap money on new parts.
Old 07-29-2011, 12:21 PM
Seagull Management
94EG8's Avatar
Did you tow it with the drive wheels on the ground? If so it's toast.
I can't even give them away around here.
Old 07-30-2011, 12:31 PM
Why would it be toast I put it in natural?
Old 07-30-2011, 12:57 PM
Seagull Management
94EG8's Avatar
Lack of lubrication. It doesn't matter if it's in neutral or not, you don't tow with the drive wheels on the ground. (unless it's a RWD or 4WD and you remove the drive shaft for the wheels on the ground) I've seen guys ruin perfectly good transmissions this way.
Old 07-30-2011, 02:54 PM
It was only a block away
Old 07-30-2011, 02:59 PM
The Grumpiest
grumblemarc's Avatar
And? Distance was obviously irrelevant. Start shopping for a new transmission. Lesson learned. Who towed it? Professionals? Or you and your buddies?
Old 07-30-2011, 07:13 PM
I did...is it different with a standard as a automatic? Cause I've towed like 3 other Honda's that where a standard. When I towed them like that and they where fine the entire time I had them....transmission wise that is.
Old 07-30-2011, 07:18 PM
Seagull Management
94EG8's Avatar
It is, that said you shouldn't really tow manuals with the drive wheels on the ground either, you can fry bearings in them from lack of lubrication.
Towing for 1 block probably didn't screw anything up any worse than it was, but you don't have to go very far to kill a transmission that way.
Old 07-30-2011, 07:37 PM
Yeah I doubt .2 of a mile will hurt it so far it drives more than when it messed up. When it messed up no matter how many times I restarted it, all it would do is rev up. Now everytime I go out it will go till about my entrance or until I change gears. I just wanna fix it then finish paying it off so I can trade it for another standard. At least if one gear goes out you just go to the next lol
Old 07-31-2011, 12:04 PM
could the sylinoids on the tranny be bad?
Old 07-31-2011, 02:24 PM
Seagull Management
94EG8's Avatar
Highly unlikely. In all likelyhood your tranny is toast dude. They don't normally suffer from electrical problems.
Old 07-31-2011, 06:36 PM
visormurp's Avatar
It really sounds like your tranny is kaput. From everything you've said, this was exactly what the auto tranny in my 95 sol did. The good news is that finding another probably won't cost too much. You can find good used ones for $300 or less as opposed to $1500 + for a rebuilt.
Old 08-01-2011, 06:33 AM
Well eff me! This is my first automatic and now I know why I stayed away from them!
Quick Reply: 99 automatic civic wont go into gear
