99-00 usdm ek/ jdm ctr climate control installation ?
Does the 99-00 ek" usdm climate control harness, plug and play with the jdm ctr climate control, also can you swap the us vents ?
Modified by jdmmanek at 8:59 AM 11/18/2007
Re: 99-00 usdm ek/ jdm ctr climate control installation ? (jdmmanek)
i dont know?, i would like to know too
is the 96-98 climate control panal any different form the 99-00 climate control panal?
Re: (camarine2003)
READ my my friend READ at the top of the Honda Civic/Del Sol (1992 - 2000) form it say NEW FAQ'S INDEX - '92-'00 Civic / Del Sol than read the FAQ's
Interior Alterations
'99/'00 Civic Climate Control In '96-'98 Civics
https://honda-tech.com/zerothread?id=605432
the harness is plug and play however that is pretty much where it ends. i have 99-00 ctr climate control housing w/the a/c heater controls and it plugs right up. it fits in the dash as the usdm one does however the vents dont mach up as they are on opposite sides. the metal brackets for the radio that attach to the climate control housing do not match up either to the car itself. you would need the jdm ctr a/c ducts for the center and rig the ends of the center vents some how(cut and glue??) so they would attach to the ctr climate control and properly deliver cold or hot air.
Re: (h22ek9forme)
you need to change the whole heater and a/c stuff.. here:
so much work..
so much work..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmmanek »</TD></TR><TR><TD CLASS="quote">Does the 99-00 ek" usdm climate control harness, plug and play with the jdm ctr climate control, also can you swap the us vents ?
Modified by jdmmanek at 8:59 AM 11/18/2007</TD></TR></TABLE>
i found that the vents from a 96-98 are better fitment.
I never narc'd on nobody!
9 year old thread
Don't thread necro like that. Ever. Period. Go read the rules sticky, then go put in a modicum of effort in searching. If that still doesn't work, then make your own thread - don't bump someone else's.
fmm999
01-16-2016 03:05 AM
JDM_black_coupe
12-06-2008 03:49 PM
