99-00 SI rear sway bar installed in 96 EX
we have been robbed!!!
all civics should have these! even though it's hella small diameter, it really tightens up the back. it barely cleared my greddy exhaust though.
took all of 20min to install by myself....I give this mod out of 5....I recommend it to everyone!
I'll get some pics tomarrow
Re: 99-00 SI rear sway bar installed in 96 EX (Mr. Suarez)
That's what my face looked like right after i installed mine...
Re: 99-00 SI rear sway bar installed in 96 EX (JV)
yeah I bet....my suspension is pretty much done....so I think thats why I can get away with it for now....but thicker would be amazing I'm sure!!!!
well actually the bar seems to fit ok...it's the bracket that holds the bar that bangs on the exhaust
I did that mod as well...definitly noticed an improvement.
Too bad the bar was a little bent, and the end link made lots of noise when I hit bumps. If I get another swaybar in back it is going to be something bigger by ST i think.
Re: 99-00 SI rear sway bar installed in 96 EX (HXMan)
it's soo small LOL, but it does make a pretty big differance over not having one at all.
New User
so it fits perfectly with no mods on a 96 civic EX? I really want to know because I'll go buy one. I was about to get the skunk2 sway bars. Let me know. Thanks.
Re: 99-00 SI rear sway bar installed in 96 EX (Spade)
yeah it's a complete bolt in w/ no modification, just make sure you get all nuts, bolts, and brackets.
Re: 99-00 SI rear sway bar installed in 96 EX (dogpile5)
will the type r bar fit w/ out modification? using existing mounting location and end links
i believe you have to buy the beaks kit for EK just to be on the safe side. total project for me was about $150 (all hardware). depends on how tight you want you back end to be...
[Modified by dogpile5, 3:00 PM 8/21/2002]
yeah the back is already tight, I don't think I'd want to go over 18mm on this car...22mm seems like serious overkill.
I did the same mod this past weekend. Quick and easy suspension upgrade
started a thread about it but died quickly.
Mr. S: what kind of rear tie bar do you have?
[Modified by LANL02, 4:20 PM 8/21/2002]
Re: 99-00 SI rear sway bar installed in 96 EX (LANL02)
I got my SI bar for 25 bucks shipped, and spent about 60 bucks on misc mounting ****
thats what I thought but I haven't seen the black one.I have the neuspeed too except in polished. It looks kind of sunnarific at night but it gets the job done
got mine for 30$ including all mounting stuff.. didn't even install it (too lazy I guess.. But the time I realized it was sitting in my room, I was already parting the car out) sold it for 60$
1 Post
Re: 99-00 SI rear sway bar installed in 96 EX (padraf)
I wouldn't go with the ITR rear bar unless you had the Si fron sway.
You'd probably have way too much over steer without something up front.
The Si front and ITR rear sway is the best combo known to man. Oh man, serious fun
1 Post
Problem is you can't run a 99-00 Si front sway bar unless you have the Si A arms and such....
1 Post
Re: 99-00 SI rear sway bar installed in 96 EX (cr00klyn718)
does the ITR front one fit without ne probs?
