99-00 si cd player into an eg hatch?
of course
but you need a 99+ harness end - http://cgi.ebay.com/Reverse-Ac...wItem
(This is cheap - I have the same one in my beater ed6)
You will be cutting your factory harness end off, or removing all the pins, rewiring to a 99+ end
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">of course
You will be cutting your factory harness end off, or removing all the pins, rewiring to a 99+ end</TD></TR></TABLE>
Or you could not be ghetto and buy the harness for your car, and wire that to the reverse harness...
That way, it'll be plug & play and you won't have to worry about splicing wires in the radio cavity...
thats what i figured, by both harness and wire them together. so on one side it will plug into the new radio and on the other side it will plug into the original harness.
Re: (o_no_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o_no_vtec »</TD></TR><TR><TD CLASS="quote">thats what i figured, by both harness and wire them together. so on one side it will plug into the new radio and on the other side it will plug into the original harness. </TD></TR></TABLE>
You are correct, sir.
Wire the 2 harnesses together, matching color to color.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">so you have a whole foot of extra wiring behind the dash??
How is repinning the connector ghetto??????????? </TD></TR></TABLE>
You never said "repin". You said cut the plug off. That is ghetto.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">You will be cutting your factory harness end off, or removing all the pins, rewiring to a 99+ end</TD></TR></TABLE>
looks like i did
looks like i did
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">You never said "repin".</TD></TR></TABLE>
Re: (pdiggitydogg)
................ 99+ Honda Reverse Harness ................ + ................ Pre-99 Honda Radio Harness ................
Both can be purchased from autoware302 on eBay for little less than $14 shipped (for both!). Click on the above links to the auctions.
I soldered to two harnesses together and had it plug and play.
Re: (o_no_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o_no_vtec »</TD></TR><TR><TD CLASS="quote">does anyone have a picture of what a 99-00 si cd player looks like? i know it lights up in amber. that why i want one</TD></TR></TABLE>
see my signature - I have one for sale
H-T White Ops
Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote"> +
I soldered to two harnesses together and had it plug and play.</TD></TR></TABLE>
This is what I did in my '98 EX. I have the '99-'00 Si deck in it and the harness is very short. It is long enough to plug in with no problems but does not have a lot of extra long wires in there.
Here is a photo of my Si deck shortly after my car was recovered.
Re: Re: (truevietluv636)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truevietluv636 »</TD></TR><TR><TD CLASS="quote">97+ Prelude Decks also light up amber. </TD></TR></TABLE>
Yup, and also plug and play into 92-95 Civics.
1 point 6
10-06-2005 08:19 AM
eg6Nrps13
07-27-2005 11:00 PM
MidwestSi
03-11-2005 06:57 AM
