99-00 Si b16a radiator into EG...
have a b18c and i have to force the tubing. said that 99 si radiators wil bolt right on like stock onto EGs? true? or custom?
same clip on top and stock fans bolt on? let me know on this.. or else im going fluidyne... but let me know on this first.
Re: 99-00 Si b16a radiator into EG... (EF8_Fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8_Fan »</TD></TR><TR><TD CLASS="quote">i could have sworn all 92-00 civic radiators are the same.</TD></TR></TABLE>
Not true. There is a dual core that came in (I THINK)the Del Sol VTECs and the auto EXs. They all should bolt in though.
Re: 99-00 Si b16a radiator into EG... (wizzards581)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 »</TD></TR><TR><TD CLASS="quote">have a b18c and i have to force the tubing.</TD></TR></TABLE> what tubing are you talking about? are you talkin about the upper radiator hose? if you are, you can bend the si one to fit, or you can just get the gsr upper radiator hose
Re: 99-00 Si b16a radiator into EG... (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Not true. There is a dual core that came in (I THINK)the Del Sol VTECs and the auto EXs. They all should bolt in though.</TD></TR></TABLE>
sorry, i meant to say, fit the same.
Re: (daddymaxx)
well i have b18c in my EG... i have the stock EG radiator. im using the stock upper one and have to force the tube onto the head. the bottom tube is GSR and is very big for the radiator. i just want to be safe and have a bigger radiator. the b16 del sols and 99 si are about the same arent they? i want to be able to use the GSR tubes and not the small EG ones.
Re: (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi »</TD></TR><TR><TD CLASS="quote">all 92-00 civic radiators fit and mount in the same</TD></TR></TABLE>
thats what i said
thats what i said
Re: (wizzards581)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 »</TD></TR><TR><TD CLASS="quote">well i have b18c in my EG... i have the stock EG radiator. im using the stock upper one and have to force the tube onto the head. the bottom tube is GSR and is very big for the radiator. i just want to be safe and have a bigger radiator. the b16 del sols and 99 si are about the same arent they? i want to be able to use the GSR tubes and not the small EG ones.</TD></TR></TABLE>
use the gsr upper hose. it'll fit on the motor fine, but get some new clamps to tighten it down onto the eg radiator. i used teg upper and lower hoses.
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
use the gsr upper hose. it'll fit on the motor fine, but get some new clamps to tighten it down onto the eg radiator. i used teg upper and lower hoses.</TD></TR></TABLE>
thank you! this is exactly what i needed to know.
question: are the 94+ integra radiators fit the brackets for an EG? an H-T member is selling a new integra radiator and i'm thinking of buying it, but i wanted to make sure it fits stock.
civichatch67
10-21-2005 06:37 AM
asocallocal
12
06-02-2005 09:04 AM
