99-00 JDM Civic type r headlamp wiring?
hi. just wonderin how to wire your JDM CTR headlamps so that when u turn on your lights all the way, only the h4 bulbs will be on NOT the turn signals. then when u flip the **** to signal, then that's when the turn signal start blinking. let me know. just to let u know i saw this in the Philippines when i was down there a couple of weeks ago. i thought it looked good. thanks...
-joe
-joe
Re: 99-00 JDM Civic type r headlamp wiring? (LiLJoESi00)
i would guess cut the constant wire in your blinker bulb wiring. it should be the black wire with the red stripe.
Re: 99-00 JDM Civic type r headlamp wiring? (Kid1320)
but will it still blink if i cut the constant wire when i need to signal left or right even if the headlamps are not turned on. thanks...
-joe
-joe
i believe so... there are three wires. i've have not done it, it was just my guess... try it, it should work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid1320 »</TD></TR><TR><TD CLASS="quote">i would guess cut the constant wire in your blinker bulb wiring. it should be the black wire with the red stripe.</TD></TR></TABLE>
yes he is correct - technically this wire (w/red stripe) should go to the city light corner lamps will only blink for the turn signal
silentdeath12886
07-10-2007 01:07 PM
imadigitalgod
Audio / Security / Video
03-05-2007 07:37 PM
