99-00' Civic Si dash into 92-95 HB???????
Okay guys I've heard and saw a 94-up Intergra dash into a 92-95 Civic Hatchback, So I want to know can you put a 99-00 Civic Si dash into a 92-95 Civic Hatchback??? I like the 99-00 Si dash better than the 94-up Integra dash!
Re: 99-00' Civic Si dash into 92-95 HB??????? (112480)
Have an 00 Si dash in my 93 coupe. I don't recomend it as it does not bolt up in any way at all. Slightly two narrow at the front by a mm on each side, slightly too wide where it meets the doors. Therefore the fit and finish is not that great unless you do a lot of work on it. The wiring up of the gauge cluster was easy, the dimmers wire right in, have to rewire the hazards. Also if you use the Si center console figure out how you want to keep your rear window defrosters as there is no individual button for it on the Si center console. I put my climate control in the bottom part right above the cupholders, looks decent. You also have to remove the passenger side airbag for it to fit nicely. The biggest problem was the metal frame of the Si dash will have to be cut up unless you want to cut up the Civic which I personally don't recomend for safety sake. The drivers half will have to be cut up and taken off.
Then custom side panels will need to be made because it looks fugly withot them and the Si ones do not fit. The center console part fits quite nicely between the seats, but only with the entire dash in. You will have to make some metal tabs and weld em in and drill a hole in them to give an anchor point so you can secure the console down. Mine still sits higher than I would like for it to, I'm considering taking it out and doing a custom dash like I did in my Jeep previously, but we will see...
I'll tke some pics over break and post them afterwards. I'm going back to my moms over break and getting my body workfinished and get a shot of paint so I'll sanp some photos, but no internet accsess at my moms so I'll have to post after the new years.
