99-00 Civic Si Cruise Control button light
I've got a 00 Civic Si and the Cruise Control button that lights up green when pressed has burned out.
Just to clear this up, I am NOT talking about the in dash cruise control light when the cruise speed has been set. Yes cruise control works, I am specifically talking about the light on the button that's located next to the sunroof control.
I know this is such a small thing, but just curious what is the best way to replace it?!
Thanks!
Thanks!
Re: 99-00 Civic Si Cruise Control button light
pop out the vent. you will see the bulb, you have to turn the base and it will come out. the bulb + base come together.
Oh look, I can change this
Replacements are a rip-off at the dealer. Here's the DIY you want: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-changing-light-bulbs-1992-1995-rear-defrost-cruise-foglight-switches-1780237/
In future, check the main FAQ thread - your question was answered there.
Replacements are a rip-off at the dealer. Here's the DIY you want: https://honda-tech.com/forums/showthread.php?t=1780237
^ Yes, you need to see the forest for the trees: You're missing the fact that all those little bulbs are often all the same on nearly all Hondas of similar 90s vintage.
Meaning you could, on your next visit to the junkyard, grab yourself an armful of those bulbs (with base) and be able to replace any burnt-out bulb for the next 20 years, all for next to no money. And certainly less than what the dealer would charge you for ONE bulb.
Midori Green
10-27-2008 07:24 PM
