99-00 civic si
Re: 99-00 civic si (hanson said)
ive already replied to a few threads like this...do da search
pm me if you have q's but here are some cliff notes to most basic n/a mods on a budget
aem cai
jdm dc 4-1
2.5 high flow cat (or no cat at all) w/ 2.5 piping
ctr intake cam(yes just intake, exhaust is almost identical) or if you have the money buy some more agressive cams
tunable cam gears
vafc and tuning.....
im prolly forgeting a few things but its a start
aem cai
jdm dc 4-1
tunable cam gears
Re: 99-00 civic si (Drunk-N-Munky)
what about an ITR exhuast cam? i heard CTR intake ITR exhuast is a good combo
Re: 99-00 civic si (nasi)
The setup for any N/A B16 motor is pretty damn broad. CTR intake and ITR exhaust are the exact same as getting both CTR Intake and exhaust. (And than theres the years that the itr switched to the same cam the ctr uses)
Anyways, what you may want to consider is dropping on a 1.8 liter engine. Persay, an ITR or GSR block(on the gsr block, you will need to up the compression) The head on the B16A2 is the same piece as on the ITR, with different internals and a light P+P job. So, decide on what route cam to go, CTR being the smallest uprgrade. Personally I would go with Skunk2 Stage-I or Toda Spec A cams. More high end, and much more mid-range than the CTRs.
Check out the N/A section on http://www.clubsi.com should also give you some more ideas.
Btw- since you're from mission viejo, all the shops are local to go ask questions @, like brandon at inline4, jeff at importbuilders.......and we have CSI meets all the time
jus f0 dekarayshunZ
ctr intake cam is the same as the 00-01 spec itr intake came....any other itr year before 00 has a less agressive intake cam....exhaust cams are the same....im all motor with basic boltons on my si
TYPEone 4-1
TYPEone B-Pipe
AEM Cai
A/C and P/S removed
Hi-Flow Cat
TYPEone 4-1
TYPEone B-Pipe
AEM Cai
A/C and P/S removed
Hi-Flow Cat
Re: 99-00 civic si (CiRcUiTsi)
TYPEone 4-1
TYPEone B-Pipe
AEM Cai
A/C and P/S removed
Hi-Flow Cat
TYPEone 4-1
TYPEone B-Pipe
AEM Cai
A/C and P/S removed
Hi-Flow Cat
Former Moderator
Re: 99-00 civic si (EGStreetHtch)
All this talking and not one damn dyno sheet...
Dyno sheet within the next 5 replies or I'm locking this one down.
Re: 99-00 civic si (B18C5-EH2)
heres a dyno of a stock b16 with i/h/e...
two more dynoes from www.bseries.net
JDM B16A block
Stock B16A PR3 head
ITR valve springs
ITR lost motion assembly
ITR cams
skunk2 cam gears
CTR pistons (~12:1 CR)
DC 4-2-1
open exhaust (little resonator)
ITR intake manifold
stock airbox w/K&N drop in & cold air ducting
stock throttle body
skunk2 ECU
Field SFC-VTEC
balanced bottom end
ITR clutch
Muller aluminum flywheel
182.1 whp (SAE Corrected)
122.9 ft-lb (SAE Corrected)
ported head
ported intake manifold
CTR cams
Stock valves with after-market valve springs
68mm Throttle-body
The motor makes peak power @ 9350rpm. At the drag strip, we shift it at 10,000rpm. The car runs consistent 13.1, but we have recorded a 12.9sec pass (full interior). The interior has recently been stripped, but we haven’t taken her to the strip since
189.6 whp (SAE Corrected)
113.2 ft-lb (SAE Corrected)
JDM B16A block
Stock B16A PR3 head
ITR valve springs
ITR cams
skunk2 cam gears
DC 4-2-1
ITR intake manifold
stock throttle body
skunk2 ECU
Field SFC-VTEC
balanced bottom end
ITR clutch
ported head
CTR cams
68mm Throttle-body
Re: 99-00 civic si (ProEater)
Cool.. That's what I thought.. Those times in a PIG COUPE/SI didn't seem right.. I know a guy on this board who has CTR pistons, CTR cams, slightly milled head, JDM 4-1 header, BC Spec II exhaust with hf cat and he runs around a 13.8-13.9 with aprx. 180 whp.. You have nice #s
i like the last two #'s. i'm gettin my B16 in a few weeks and with #'s like that i'm lookin foward to havin it in my hatch.
**EDIT**
Q: what yr hatches and where they stripped in anyway?
[Modified by EB_kid, 11:44 AM 3/6/2003]
**EDIT**
Re: 99-00 civic si (EB_kid)
**EDIT**
Here is my best dyno
When I dynoed I had:
182HP, 134Lb-Ft
B16A head, mild P&P
B18C1 Block, PR3 pistons 11.1:1 CR
GSR Cams, ITR Valvetrain
ITR IM
JG 64mm TB
APEXi N1 Catback
APEXi GT Header
APEXi VAFC
P28 ECU w/ Mugen Chip
AEM CAI
B&M FPR
I'm in the process of collecting parts for a new setup. Best time in my 99 Si, 13.7@99.6mph
[Modified by AzSi22, 3:08 PM 3/6/2003]
182HP, 134Lb-Ft
B16A head, mild P&P
ITR IM
JG 64mm TB
APEXi N1 Catback
APEXi GT Header
APEXi VAFC
AEM CAI
B&M FPR
Re: 99-00 civic si (AzSi22)
182HP, 134Lb-Ft
B16A head, mild P&P
ITR IM
JG 64mm TB
APEXi N1 Catback
APEXi GT Header
APEXi VAFC
AEM CAI
B&M FPR
182HP, 134Lb-Ft
B16A head, mild P&P
ITR IM
JG 64mm TB
APEXi N1 Catback
APEXi GT Header
APEXi VAFC
AEM CAI
B&M FPR
thats whats going to be my next project too.
