98 D16y8 Intake Manifoldon a 99/00 D16y8 Head - Idle Surge
I've searched and searched.... and I've found a bunch of info I've already gone over and over again.
When using the 98 IM, can you use the 98 IM gasket on the 99/00 head? Will that promote any type of problems?
I'm getting a nasty idle from 1000-2500 rpms while the car is in park. However when in drive/reverse the surging goes away. This is an AT by the way.
I've checked for vacuum leaks, changed iac's, used carb cleaner to inspect gasket leaks, you name it I did it.
Re: 98 D16y8 Intake Manifoldon a 99/00 D16y8 Head - Idle Surge (PrecisionH23a)
New TB gasket and cleaned ICV fixed it.
I used the 98 IM and im gasket on the 99 head.
demas16
18
06-03-2014 06:41 PM
Onimuno
02-06-2014 09:27 AM
