98 CX converter changed?
Had my dad take my car to he his shop and he said need I need to change the converter? whats a converter? Is it the piece from the Header to the Exhaust pipe?
Oh i had it checked because my CEL was on and he said that might be one of the problems..so i just thought I came on here to get a little more info on it
and where i can get a cheap price for one if I do need one
H-T White Ops
Re: 98 CX converter changed?
P0420 is catalyst system efficiency below threshold (bank1).
When you get the codes scanned at Autozone they can enter any code into the part number search on their computers there and print out a piece of paper that says what the code means and what the common causes for that CEL to come on are.
This one should mean you have a bad catalytic converter though.
Hmmm sounds kinda bad and expensive!
Someone told me i can put a Spacer somewhere? but i had no idea what he meant by that..
get a stock cat for an EX as well as the header and catback and convert it like i did
http://www.d-series.org/forums/n00b-...-n00b-n-h.html
I think the CX motor is different from an EX motor and its catalyc converter is different as well..
The picture RonJ posted up is the exact same look as how mines look
H-T White Ops
EJ6-2nr is saying to remove your exhaust manifold (which contains your catalytic converter) and B-pipe. Replace them with an exhaust manifold, catalytic converter (mounted under the car) and B-pipe from an EX.
you still have to swap out exhaust or have a exhaust shop fab the cat in from a ex.. i did this as well those cats are known to crack they had a recall on them a long time ago. i bought a cheap header, hi flow cat from random technology and hks hi power exhaust
NssOne_EK
04-04-2009 10:10 AM
