98 Civic - Fluctuating/high engine temperature after heater/cooling system work
#26
The Grumpiest
Re: temperature guage problem
Is there a manager to speak to or is he the manager? Small claims court if you don't get satisfaction. Let him know that. I have a shop that I go to that gives me excellent service when there's a job I can't do myself.
In the meantime...bleed the air out of the system.
#27
Re: Fluctuating/high engine temperature problem after heater/cooling system work
1) Tell us what car you have.
2) Bleed the cooling system.
3) Pull the CEL codes and then reset the ECU (see FAQs sticky). If the CEL turns on again while driving, then pull the codes again. Post those codes.
#28
Air. In. The. System.
Did we at least check that?
And get an OEM thermostat. That's easy enough to change out your self.
But I would have returned the car to them the minute I had problems.
Also I suggest you learn more about your car. $250 to change a radiator is outrageous. I told my wife how to do it and she did the job in less than 40 minutes.
x2
I changed my civic's radiator in about 30 minutes and ended up costing me like, $85 with new radiator, new rad. cap, new hoses, clamps and transmission hoses.
Also x2 on air, that can cause little issues like this, even after 2 weeks
#29
he has my money though. I'd have to dispute it if he wont fix the problem. The problem aint fixed. He thinks im an idiot. I know a little about cars i know the guage isnt suppose to jump around. Looks like most people in auto mechanics are a fraud. I've never seen an honest shop or mechanic so far.
Also, search their business online go to their listing, like yahoo, super pages etc have review sections...........write a bad review, also give them a bad report on the local BBB bureau. People do read these reviews, it will catch up to them.
#30
AMEN. That is the problem. There is air in the system.
The shop did not do the work correctly. What they did to bleed the system did not work . Air is stuck in the pipes and engine and can not get out. That's why you're getting widely varying temps. You are also in serious danger of overheating the engine and causing a cascade of damage. The thermostat installed is the wrong temperature.
#31
take the radiator cap off, run it until the bubbles stop coming up from the top. fill with more coolant/water until it's full and has no bubbles. the thermostat is wrong but that doesnt mean it should make it run that hot. when a thermostat gets to a certain temp, it stays open.
there is a gas/air bubble in the cooling system blocking flow of coolant through the engine. if you relieve the 1.1 bar psi from the radiator, the air is able to move through and into the atmosphere allowing no blocking in the system.
do that, it's easy as hell.
#32
what does a transmission hose have to do with a radiator?
#35
#36
#37
#39
The Grumpiest
OMG. With the diagram I posted you cannot bleed the air out of the system on your own? You could have done it already!!!! My wife can bleed her own cooling system for chrissakes! Why come and ask for tech advice if you're not capable of doing even the simplest of things?
#40
Wait you know something they didnt bleed it. I remember watching them install it and they just installed it and backed it up and that was it. They just waited with the car running to make sure the fans cycle they said. I even asked him to test drive the car to make sure everything was alright and he said "not at the price I quoted you"
#42
take the friggin radiator cap off and run it for 15 minutes. add coolant until full, put back on cap.
SYSTEM IS BLED. i dont understand what the problem is.
the thermostat is fine for now. it will just open later than it should at oem spec. but it's not going to break your engine. but running with air in the system will. do it.
#43
Re: Bleed
Stop driving the car until you fix the damn air in the system problem. You risk your head gasket and motor every time you take it out. There is little to no water in the cooling passages around the engine.
Also, it is difficult to impossible to bleed the car on a flat surface just running the engine and watching for bubbles.
What worked for me was putting the car on a step incline with the radiator meaningfully above the rest of the engine. Large bubbles immediately began gurgling out. That did not happen on a flat surface. A good mechanic has a funnel shaped reservoir that installs on the radiator cap and holds about a quart of coolant. By squeezing the supply hoses and refilling the device, you eventually can bleed on a flat surface.
#44
#45
#48
Yes, it matters. The thermostat must open to allow water to flow to the radiator, so operating temps, not cold.
Humphrizzle and I just pointed out that inclined is better. Humphrizzle had it work out on flat, but he's probably better at this than you are and knows what to look for. Get your car on a steep incline, radiator high, squeeze the top hose repeatedly and you're going to see bubbles (it brings hot water [in your case-air]from the engine to the top of the radiator). Burp the radiator. It could take another quart or more of coolant.
If you're able to do this, you've solved the problem.
#49
i would switch out to oem thermostat...so many aftermarket thermostats do not even open when an OEM is already FULLY opened.
ive bled coolant a lot of times and always done it on a flat surface without any problems. Doing it on an incline sounds smart though, i'll try that next time.
#50
