98 civic ex electrical issues after headlight harness tuck
i just got done tucking my headlight harness and relocating my fusebox to my glove box, i did not cut or splice any wires i strictly re ran the harness through the cabin into fenders. there is a thick white wire coming from the fuse box to the harness that seems to be a little loose from the harness itself but not sure if it was that way before, after finishing up i turned my car on to accessory to make sure the headlights worked and they did, i turned it off then realized my windows were down so i went to roll them up, put my key in and no power, wiggled the power on the terminal and i would get the beep from key being in ignition then nothing as soon as i turn it more, eventually it stopped all together with the wiggling of the terminal. i then started checking all fuses none were blown that i can see, i wiggled the condensor fan relay and it made the beep from my key again and did so for a while up until i went to do anything that involved drawing power (beeping the horn, turning on dome lights etc) some one please help. with my luck its gonna rain tonight and my car is in pieces
crookson speed
07-12-2017 06:53 PM
milkwasabadidea
07-31-2011 01:05 PM
slowcoupe93
07-03-2007 05:05 PM
