98 Civic EX - condensor fan fuse keeps blowing
Old 08-11-2012, 07:35 PM
ericestrada928's Avatar
Default 98 Civic EX - condensor fan fuse keeps blowing
hi, im new to this forum and i need your help... i live in az it gets really hot out here and i have a kid i need your guys help asap.. i have a 98 honda civic ex..a few days ago my a/c was working fine. just today i went to the store and now throws hot air. so i decided to try to find out why. so i looked and searched for the issue and the only thing i found was that for some reason the fuse 20A (condensor fan) keeps on blowing up and everything else looks fine. i change it and try the a/c and a second or two it burns the fuse again. what can be the issue? has anybody had this issue? thanks for any help!!!
Old 08-11-2012, 08:15 PM
HOMEMADEPOWER's Avatar
Default Re: condensor fan fuse keeps blowing
You probably have a short somewhere. Check your wiring.
Old 08-11-2012, 09:33 PM
I did check the wiring and everything looks fine!!!
Old 08-12-2012, 04:47 AM
Technical Hero
HondaPartsHero's Avatar
If you unplug the fan and turn on the AC does it blow the fuse?
Old 08-12-2012, 07:34 AM
Former User's Avatar
This^
It sounds like the condenser fan motor is bad due to a short. Do Hero's test. If the fuse no longer blows, replace the fan.
Old 08-12-2012, 08:01 PM
yes, it seems to blow the fuse!!
Old 08-12-2012, 08:03 PM
If you unplug the compressor clutch, does the fuse stop blowing?
Old 08-12-2012, 08:05 PM
Originally Posted by RonJ@HT
This^
i disconnect the clutch relay and leave the con. fan relay on in which the con..fan turns on and the fuse does not blow.
Old 08-12-2012, 08:09 PM
Default Re: 98 Civic EX - condensor fan fuse keeps blowing
Sounds like the clutch field coil has a short. Test it.
Old 08-13-2012, 09:55 AM
Thanks will try it..
Old 08-17-2012, 07:42 PM
Well at the end of this it was compressor making a full turn then stoping causeing my fuses to burn out..thanks for the help guys.... will change the a/c compressor and get my air back on thanks!!!!
Old 08-17-2012, 07:46 PM
I don't understand your reasoning. Why do you think replacing the entire compressor is necessary?
serGGio
20
06-16-2014 07:04 AM
demiseraph
08-05-2011 05:12 PM
ChiDubysLS-VTEC
08-07-2009 02:17 PM
immajackuup
13
05-10-2008 07:34 AM
b00sted4dr
07-25-2005 05:28 AM
Quick Reply: 98 Civic EX - condensor fan fuse keeps blowing
