98 civic b16 problem
Re: 98 civic b16 problem (BomBoi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BomBoi »</TD></TR><TR><TD CLASS="quote">the 2 sides need diffrent ones , the motor needs the one off the d seres and the passenger side needs the one off the b16 i think</TD></TR></TABLE>
nope... the two sides are the same and so is the rear, the only thing you need is a 99/00 Si rear T bracket
Re: 98 civic b16 problem (h22_crx)
u can not reuse your ex mounts..but u can re use the rear mount..in order to get the right mounts for the driver side...first.u need to make sure how many studs does your engine bracket have? normally for a b16a ..it should be 2... b18c has 3..
Re: 98 civic b16 problem (crazyguy)
yes he can reuse his mounts............ ALL 96-00 Civics use the same mounts like I already said all he needs is the rear T bracket
Re: 98 civic b16 problem (Grounded)
exactly, that is the cast iron BRACKET bolted to the block it isn't a motor "Mount", but he already has a b16 so it should already have it.....
pbomers
10-15-2003 06:26 AM
