b16a idles up and down if i tap the gas
Old 01-09-2011, 08:57 AM
jthrasher1's Avatar
Default b16a idles up and down if i tap the gas
i got a jdm b16a and the car idles fine but if i tap the gas it will idle up and down and keep doing it and there are no vacume leaks... anythin particular i should try or need...
Old 01-09-2011, 09:02 AM
Former User's Avatar
Default Re: b16a idles up and down if i tap the gas
Any CEL codes?
Is the throttle cable adjusted too tightly? it should have about 1/2" of slack.
Is the throttle body dirty, causing the throttle plate to stick slightly open?
Is the throttle cable binding?
Old 01-09-2011, 09:13 AM
Red_Army's Avatar
clean the IACV.
and do whatever ron says first ^^
i just know that happened on my car and that fixed it.
Old 01-09-2011, 09:24 AM
jthrasher1's Avatar
its got a cel light im in the process of figuring out the codes now.. and ill check the throtle cable and throtle body..and thats all good ill clean the iacv let ya know how i make out thankss
Old 01-09-2011, 11:17 AM
jthrasher1's Avatar
diddnt figure out the cel codes but cleaned throttle body and iacv and dosent do it anymore thnx fellas
Kman1371
02-14-2017 08:22 AM
Psycho719
04-17-2012 09:22 AM
UniqueX707
01-14-2012 07:17 AM
supracrx
01-07-2007 08:06 PM
DevinW
06-06-2002 02:21 PM
Quick Reply: b16a idles up and down if i tap the gas
