97 interior in 95 hatch?
Seagull Management
Re: 97 interior in 95 hatch? (keep_h8n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keep_h8n »</TD></TR><TR><TD CLASS="quote">Anyone? Is there any make/model thats a direct replacement besides out of another hatch?</TD></TR></TABLE>
'93 - '95 coupe dash, interior door panels and seats are identical to the '92 - '95 hatchback. '92 - '95 Sedan dash is identical as well, seats are slightly different but will bolt in the same. Door panels don't fit. '96 - '00 interior parts will not fit without extensive modification if they will fit at all.
Well i bought the car for parts and I started trying to fit the interior. The center consol fits well cept a small gap at the dash, dash is same length so Im going to try it also. The door panels just needed trimed on back side on the top where they slide on the door to make them fit. The seats Im sure I could use my brackets and make them work but Im not sure if Im goin to use them. The newer interior looks way better IMO so its worth a little work to me, thanks.
Seagull Management
Re: (keep_h8n)
Just kind of a heads up, but you will probably need to do some wiring under the dash, actually i pretty much guarentee that you will need to combine both dash harnesses into one. The whole swap can almost certainly be done, I just don't think the time and effort involved make it worth it, but its your project not mine.
EG6Boy702
05-02-2009 01:31 PM
Jdm_Newb_NYC
03-16-2006 02:50 PM
