'97 HX cat/header question
well me 97 hx threw 4 codes... and one of them being catalyst is not reading correctly. my car is rusted to **** in the motor bay so i am replacing my cat and secondary o2 seeing as how they both have 140,xxx on em... so, with the cat being placed right under the exhaust manifold on the hx, i was wondering if it is alright for me to convert to a cat under the car and just extend the wiring for my secondary o2 to fit right behind the cat... i cant find a good reason for honda sticking the catalytic converter so close to the head, and to replace it with the same is soooooo expensive. so i was gonna buy an ex/lx/dx obd2 manifold and convert it to cat under the car... any opinions or suggestions would be great.
thanks
thanks
Re: '97 HX cat/header question (pubestripe)
I don't think it will just bolt right up because the b pipe on hx/lx/dx is longer than on an ex because the ex pipe makes room for the cat. You could probably cut a chunk off and weld the cat onto the pipe instead.
Re: '97 HX cat/header question (sniggler316)
yeah i know it wont bolt right up, i have to re-weld part of the exhaust anyway.
i bought a universal cat too so it doesnt even have flanges...
thanks for the responses though!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniggler316 »</TD></TR><TR><TD CLASS="quote">I don't think it will just bolt right up because the b pipe on hx/lx/dx is longer than on an ex because the ex pipe makes room for the cat. You could probably cut a chunk off and weld the cat onto the pipe instead.</TD></TR></TABLE>
dude hes goiong to replace the entire exhaust system ..
Re: '97 HX cat/header question (96dxpower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dxpower »</TD></TR><TR><TD CLASS="quote">
dude hes goiong to replace the entire exhaust system .. </TD></TR></TABLE>
Actually, I don't see where it says that in his post but if you can read minds hey good for you...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniggler316 »</TD></TR><TR><TD CLASS="quote">Actually, I don't see where it says that in his post but if you can read minds hey good for you... </TD></TR></TABLE>
lol im not. i should have said that i have a welder and tube bender though...lol
Yeah, shouldn't be a problem if you know what you are doing. I don't see why Honda did the cat that way either and like you said, replacements are effin expensive! I'll probably do somethi8ng like this or just run it with an aftermarket header and no cat when mine goes. Let me know how it works out for you.
yeah i will for sure let u know. i was going to get an aftermarket header but this is just my daily driver... so i wanted to keep it all oem.
im pickin up the header tonite and getting the cat on wednesday so ill let ya know!
Stock90Civic
16
01-15-2009 05:48 AM
