97 ek need help 1500 rpm jumpy n running super rich
any help is apreciated .it started to do it with old head then gasket went out so i dropped a z6 head on. i changed out iac valve tryed like 3 map censors changed out tps.tryed another ecu n all the same
Re: 97 ek need help 1500 rpm jumpy n running super rich
I got a tps off a car in junkyard n switched it out but even eith old tps it wud do same it had just started one day the car rpm wud bogg for a sec or too n feel like losing power until it was constant now its jumpy at 1500 rpm n runnin rich like really rich
you still need to calibrate/check for dead spots http://forums.g2ic.com/showthread.ph...8C-*Sir-G-spec)
Mr.Galloway
10-03-2014 09:11 AM
Iloveyourhonda92
07-04-2010 12:48 PM
