97 ek hatch y8 swap wnt start
K here's some details I jst bought a Ek hatch with a y8 swap in it car ran and drove had the car at 5500 rpms and then it jst quit and dropped rpms till 3 grand and chugged a lil got it home fired it up an drove fine for about a 20 mins then started chugging n jerking at lower rpms till it jst stopped and wouldn't fire maybe once out of the 10 tried towed it home fired up after a few more tries out it in gear and died and haven't started since cel light don't work I replaced dizzy with my buddies added gas hear the pump still have to check spark but in Wisconsin she's still cold out jst hopping to get a good hint of wat it might be could it if jumped timing?
If you loved me, you'd all sell me your magic cards to me today
Re: 97 ek hatch y8 swap wnt start
First, it is not an "EK Hatch" it is an EJ6 as sen here:
What ECU is the car using? Does the CEL(check engine light) work, if so do you have any CELs? Is it a 5 speed or an automatic? Are there any mods done to the car?
EG1 - USDM 93-95 del Sol D15B8 (8-valve)
EG1 - USDM 93-95 del Sol S D15B7
EG1 - USDM 93-95 del Sol VTEC-E D15Z1
EG2 - JDM 92-95 Civic hatch/sedan/CR-X B16A
EG2 - USDM 94-95 del Sol VTEC B16A3
EG2 - 96-97 del Sol VTEC/SiR B16A2
EG3 - JDM 92-95 Civic hatch/sedan D13B
EG4 - JDM 92-95 Civic MX hatch/sedan/CR-X D15B
EG5 - JDM 92-95 Civic n/a ? (ZC DOHC)
EG6 - JDM 92-95 Civic SiR hatch/sedan/CR-X B16A
EG6 - USDM 96-97 del Sol S D16Y7
EG6 - USDM 96-97 del Sol Si D16Y8
EG7 - JDM 92-95 Civic EL hatch/sedan D13B
EG8 - JDM 92-95 Civic VTi hatch/sedan/CR-X D15B VTEC
EG8 - USDM 92-95 Civic DX/LX sedan D15B7
EG9 - JDM 92-95 Civic SiR hatch/sedan/del Sol CR-X B16A VTEC
EGN1 - JDM 92 Civic sedan 1.6L ZC
EH1 - JDM 92-95 Civic sedan/4WD (ZC DOHC)
EH2 - USDM 92-95 Civic CX/VX/DX hatch 1.5L
EH3 - USDM 93-95 Civic Si hatch D16Z6
EH6 - USDM 93-95 del Sol Si D16Z6
EH9 - USDM 92-95 Civic EX/ESi sedan D16Z6
EJ1 - JDM 93-95 coupe D16A
EJ2 - USDM 92-95 Civic DX coupe 1.5L
EJ3 - JDM coupe / 4WD 1.6L ZC
EJ4 - JDM CRX del Sol D16A
EJ6 - CANADA 96-00 Civic CX/CX-G/DX/DX-G/EX/LX/SE/Si coupe/hatch/sedan D16Y7
EJ6 - USDM 96-00 Civic CX/DX/DX-V/LX coupe/hatch/sedan D16Y7
EJ7 - USDM 96-00 Civic HX coupe (VTEC-E) D16Y5
EJ8 - CANADA Civic EX coupe D16Y8
EJ8 - USDM Civic EX coupe/sedan D16Y8
EJ9 - EDM/JDM 96-00 D14A2 hatch/sedan
EK1 - Aust 96-00 GLi hatch/sedan auto D16Y4 non-VTEC 88kW/144Nm
EK2 - JDM 95-99 Civic EL hatch/sedan D13B
EK3 - JDM 95-99 Civic ML LEV/VTi/Ri hatch/sedan D15B VTEC
EK3 - 96-98 Integra SJ/EXi D15B
EK4 - JDM 95-99 Civic hatch/sedan B16A
EK5 - JDM 95-99 Civic 4WD/LEV RTi sedan D16A
EK6 - 95-99 Civic hatch
EK7 - 96-00 Civic hatch LSi 1.5L VTEC
EK8 - JDM 95-99 Civic 4WD/LEV sedan D16A
EK9 - JDM 97-00 Civic Type-R hatch B16B
EL1 - 96-00 Orthia (Partner) SJ B18B
EL2 - 96-00 Orthia (Partner) 2.0GX B20B
EL3 - 96-00 Orthia (Partner) 4WD 2.0GX / 4WD 2.0GX-S B20B
EM1 - CANADA 99-00 SiR coupe B16A2
EM1 - USDM 99-00 Si coupe B16A2
In the Honda community everyone knows EK refers to 6th gen Civics, EG refers to 5th gen, EF 4th gen, etc. It might not be technically correct, but everyone knows what he is talking about.
He said the CEL light was broken. I would start with a code reader. Your CEL might not work but you want to read the codes that are stored, if any. AutoZone or any auto store will read the codes off your car for free.
Assuming you have the correct ECU, and the wiring is all correct for the swap, I would start at the basics. Check and make sure the timing is set correctly. You also need to check compression. If compression and timing are good, I would look at the O2 sensor because you mentioned it chugging and jerking at lower RPMs. A bad O2 sensor causes the ECU to send extra lean/rich mixtures causing misfires and loss of power. And it also explains why the car runs fine for 20 mins in the cold, because during warmup the car is in open-loop mode, ignoring the O2 sensor. The way to test the O2 sensor is to simply unplug it. If the car runs fine with it unplugged after it's warmed up, you can assume your O2 sensor is bad.
If all of the above checks out, and the car is still having problems, I would start with a basic tune-up before spending money/time anywhere else. Cap/rotor could cause the problems you are mentioning. Do a full-tune up.
Last edited by Former User; 04-04-2014 at 04:06 PM. Reason: Post edited to remove non-technical comments
I missed the CEL light being broken part. OP swap a bulb from elsewhere in the cluster to the CEL, check the CEL codes as shown in the FAQs of this sub forum.
And yes chassis codes matter, there have been a few instances this week in these sub forums where chassis codes would have helped the OP out quicker instead of other having to ask for more information.
Example of this, what engine does an EK coupe come with?
He said EK hatch, and we can assume its a US car because US 6th gen hatches only came with a D16Y7. So giving the specific chassis code really doesn't help.
Last edited by Former User; 04-04-2014 at 04:10 PM. Reason: Stay focused on tech and direct your responses only at the OP
Identifying chassis codes may help OP later identifying problems, and I also helped by providing some more items that could help diagnose the problem.
Also in the rules sticky identifying these things is required.
It's got no spark I have changed a few grounds and cleaned up the spots an a new battery I have also tried 3 ignition modules and coil packs and a different cap n rotor and a different dizzy and still no spark and the cluster has no light in cel spot so goin to add a bulb and go threw the codes
Sliced Beard
11-02-2004 11:11 PM
Tyson Ballou
14
02-24-2002 10:19 AM
