97 ek civic wont rev past 4500
Ok so I swapped my ek hatch with a LS I had from my DA it idles fine it drives fine but wen I decide to step on the gas it chokes at 4500 but if I don't. Floor the gas pedal it goes all the way up to redline my car is obd 2 my swap was obd0 but I'm running a obd1 dizzy nd alternator I've tried diffrent ecus diffrent wire harness dizzys nd nothin any help would b greatly apreciate
Re: 97 ek civic wont rev past 4500
no but it was running fine in my da but i also had a b16 in it firs that i got off my brother also working fine in his hatch but it had the same problem it has now i thought it was timing so i put the ls in
I had the same issue when I installed my edelbrock manifold and throttle body....check tha tps denser cuz it has 2 hot wires one is a cons and other 1 is a 10-12 volt switch those wires and u should b good....hopes it helps
Technical Hero
why would the wires be swapped? Do you have a check engine light on for anything? What injectors are you using? What ECU? Are you using a distributor adapter and ECU adapter? If everything was working fine in your DA its probably a wiring issue of some sort.
im running obd2 injectors obd1 ls distributer with a step down obd1 ls ecu with a step down the obd1 alternator plug is added to the harness it came like that on all three harness i used the stock one then i got a ex one then i just bought another stock one i tried to get one thats not cut but the kid lied to me i tried switching the plugs on the tps with map but its not that
when i was searching it people had the same problem so i tried alot of things so far some where i read i could be the fuel pump or fuel filter could that be my problem ?
Na I was talking about tha tps cuz I had that issue when I installed a 70mm mustang throttle body on the jg manifold and u hav to hard wire tha tps wires 2 tha tps wires on my harness and run a hose off of tha map senser 2 make everything work like stock
im running a stock ls throttle body i tried three of them same problem i made the distributor step down myself so i wouldnt have to cut anything but i tried a obd2 distributor from my cuzins hatch same thing
how do i check if im getting enuff fuel im starting to think thats the problem could my fuel pump be bad ? thanks for all ur help
i still havent been able to find out wats wrong with my car my friend said it could be my interior harness dose the interior harness have anything to do with my bogging problem
it seriously sounds like the wiring in the tps sensor ... i have a eg civic and when i swapped the jdm gsr in it i had alll kinds of problems with the tps sensor ... it would rev slow passsed 4500 but wide open it wouldnt it ... i would try and demount the tps sensor and remount it and calibrate it and make sure that your wiring to it is correct ...
