97 Del Sol Si - no crank, lights yes
Hi guys i am new to the forum and appreciate you advice.
Got a 1997 Del Sol Si that is not turning, lights come on though. when you push the car and pop the clutch it turns on fine. So thinking it may need a starter. Please any suggestions and where can i get a starter/part number. Thanks |
Re: 1997 Del Sol Si no crank lights yes
probably, or your clutch switch isn't getting contact.
Originally Posted by tony_2018
(Post 49558522)
agree with poster above, it has happened to me on 2 cars. If you look up under the dash at the clutch pedal you will see a lower and upper stopper, the top one is the one you need or you can just bypass it so you dont need to push the clutch to start.
Re: 97 Del Sol Si - no crank, lights yes
Thanks guys spot on it was the clutch relay - my mechanic cost me a starter only to finally listen to me and say "OH Yeah it was the relay".
