How to hook up sway bars to hardrace front Tubular control arms
Old 05-17-2018, 08:06 PM
lurice01's Avatar
Default How to hook up sway bars to hardrace front Tubular control arms
Here's what I bought and what they're supposed to look like hooked up:
Old 05-17-2018, 08:09 PM
lurice01's Avatar
Default Re: How to hook up sway bars to hardrace front Tubular control arms
Here's an example of how i was going to hook them up and i know it's wrong and something is different.
I think i need totally different sway bars.
Old 05-18-2018, 03:40 AM
lurice01's Avatar
I looked at an old email from Hardrace and must have missed this part:
"When you purchase, advise the sway bar you are using. If you are using standard EG sway bar, you will need to use DC2R Front Endlinks.
If you are using DC2R front sway bar, you will need to use the silver supplied Endlinks."
http://www.buyhardrace.com/product/hardrace-front-sway-bar-end-links-94-01-integra-gsr-type-r_27.html
cant find that part though
Is this it? Says integra only unless i got a type r or grs sway bar
Old 05-18-2018, 04:13 AM
mk378's Avatar
If you really cannot buy those or anything like it, then you would need to replace the bar with the other kind that has the attachment holes horizontal instead of vertical, which matches the links you have.
bakomack
08-08-2009 03:14 PM
lmike6453
03-09-2008 08:15 AM
SickIntegraWon
11-15-2007 08:41 PM
hatch is best
11-09-2006 11:16 AM
bebeon_ek
67
07-07-2005 09:53 PM
Quick Reply: How to hook up sway bars to hardrace front Tubular control arms
