97 civic turbine speed sensor code
Old 07-14-2009, 06:49 PM
xpdude's Avatar
Default 97 civic turbine speed sensor code
hey guys, my 97 civic threw a code. turbine speed sensor fault, and transmission computer control malfunction. just wondering if this could cause the transmission to slip in 1st gear and function normaly thereafter shifting in 2nd gear through 4th? i don't want to replace the sensor if the slipage is because the chutchpacks or gear is destroyed. what do you guys think?
Old 07-14-2009, 07:30 PM
lilj95's Avatar
Default Re: 97 civic turbine speed sensor code
do u have a manual or auto?
Old 07-14-2009, 07:55 PM
xpdude's Avatar
im sorry, its a 4spd automatic. 97 civic lx.
Old 07-14-2009, 08:12 PM
lilj95's Avatar
ok the turbine speed sensor fault is the sensor that tells the ecu how fast the wheels are moving i belive so stick another sensor it there and the other is umm i might have to get back to you on that after work tommarow ill find out though
Old 07-15-2009, 06:36 AM
xpdude's Avatar
ok, well the issue is that the transmission slips in 1st gear after it warms up and i have to shift into 2nd to take off, then i have to shift to D4 to go through the rest of the gears. my speedometer works fine! would a bad turbine sensor cause the slippage? it was weird, this morning 1st gear was holding fine for a while then it started slipping weird again.
Old 07-15-2009, 02:45 PM
xpdude's Avatar
help? anyone? can i save this transmission?
Old 07-15-2009, 06:14 PM
lilj95's Avatar
yea the turbine sensor can cause slippage besides my 95eg i have a 01 elantra and had the same prob with the turbine i replaced sensor and it fixed the prob and as for the transmission computer control malfunction i belive follows the sensor i belive
Old 07-16-2009, 11:20 AM
xpdude's Avatar
ok, i am gona try for a replacement sensor. should i??? buy a new one or get 1 from the junk? are they hard to replace? i know where they are at on the trans.
Old 07-16-2009, 07:36 PM
lilj95's Avatar
honestly when it comes to trans i take it to dealership lol i suck at transmissons im better with engine work but i know what the codes for the trans mean if u have any friends that live near u as them if they are good with transmissions but the sensor is most likely under the car with the oilpan etc....at least thats were its at on the 2009 maxima lol acura nissan dealer so im getting all this from acura techs
Matt Shreve
Acura TL, RL & ZDX
06-15-2013 02:18 PM
jlunn717
05-29-2012 04:31 PM
89EFLS
08-06-2009 04:28 PM
guyuenvy
04-30-2002 09:59 AM
Quick Reply: 97 civic turbine speed sensor code
