EG Civic - fuel pump won't prime (solved)
Old 04-20-2016, 05:18 PM
GT500FTW's Avatar
Default EG Civic - fuel pump won't prime (solved)
Hi guys.
I've got a b16a2 engine from an eg civic in my kit car.
I'm not getting spark or fuel pump priming. The ecu and main relay are tested and good, but I've made a mistake with the ignition wiring.
The main relay isn't getting a switched live signal when I turn the key to the 2nd position.
I'm wondering if its possible to run a feed directly from the ignition barrel to the switched live pin on the main relay?
Will this work? And will I get spark and fuel?
Old 04-20-2016, 05:31 PM
Former User's Avatar
Default re: EG Civic - fuel pump won't prime (solved)
Test fuses 24 and 31.
Old 04-20-2016, 08:10 PM
carlowerks's Avatar
here' a diagram
Old 04-21-2016, 01:40 AM
GT500FTW's Avatar
Fuses are all good. Its a problem with my wiring from the ignition barrel to the fuse box.
If I run a direct switched live to the corresponding pin on the main relay, will this work?
Old 04-21-2016, 03:19 AM
Fish Twig
tony_2018's Avatar
What did you do?
Old 04-21-2016, 09:55 AM
Voltage test fuses 24 and 31.
https://honda-tech.com/honda-civic-d...fuses-3079359/
Old 04-21-2016, 10:54 AM
Fish Twig
tony_2018's Avatar
The ignition switch only has about what.......4 wires going to it back to the fusebox.....how could you screw that up?
Old 04-21-2016, 12:50 PM
fcm
Old Fart
fcm's Avatar
Yes it would work, but fuse the lead and disconnect the existing 12V switched lead going to the PGM-FI Main Relay, just in case it is shorted out.
The above is a jimmy rig and would work, but I would find and fix the problem.
Keep in mind that fuse may also power other things, like the FPRS and EGR valve 94
Old 04-29-2016, 07:52 AM
GT500FTW's Avatar
That's exactly what i was thinking!
I continuity tested everything and it all seemed fine. I was pulling my hair out trying to figure this out and just thought F*** IT! I'll just bypass the problem.
When I was removing everything I knocked the Main relay and tried it again, and it worked.
It turns out my wiring was fine, the main relay was bad after all.
I tested the thing 3 times and it was ok. Turns out that when I was bench testing it (horizontally) the dodgy solder was making contact, but as soon as i installed it back in the car (vertically) the solder lost contact and wouldn't work!
Old 04-29-2016, 08:32 AM
averyvm's Avatar
Post a pic of that kit car though. I'm interested.
Old 04-29-2016, 01:27 PM
GT500FTW's Avatar
Well it's not exactly a kit car. It's more like a monstrosity of my own making.
It's a Citroen Ax. It has 2 turbo B16 engines. One in the front for the front wheels and one in the rear.
Old 11-10-2016, 04:40 PM
averyvm's Avatar
Woah
RiPe14yoU
06-10-2017 06:17 PM
djkube
06-02-2013 05:23 AM
One92Eg6
11
07-03-2010 05:59 PM
mphsrex
02-16-2009 06:09 AM
Redline130
21
04-12-2006 09:00 PM
Quick Reply: EG Civic - fuel pump won't prime (solved)
