97 civic ex b16 build
#27
Re: 97 civic ex b16 build
Yeah, should be. Even gasoline quality can vary quite a bit though. So when pushing to higher boost levels I think the ethanol sensor is worth the added peace of mind. All the components can be had for $50 and simple to install. I am thinking I will add one and just retard timing 1 degree or so for e70.
#28
#29
Hondata ethanol content sensor
It goes in your return line, and once wired into ecu you can add fuel and ignition compensation for whatever levels of ethanol you want to run.
#30
This gives a good quick explanation and list of parts needed....
Gonna tune on 93. I think 500 whp on the streets will be nasty with the right suspension. I’m running the blox drag suspension. But sorry for the delay guys I’ve been waiting on CSS to send me my **** back, The guy told me it would be two weeks and it’s been over two weeks...
#34
thank u sir. I know if he calls me while I’m st the beach and tells me my block and transmission is finished I’ll be leaving a few days early just to get my car up and running. I still ha e to do soldering for my Hondata s300 and install my warlboro 450 pump. I’m way more excited trust me. I have a few races around here that’s why i got back into it i was tired of hearing about a few guys around here lol.
#35
Also i got my rear suspension installed. (Took me longer because i had to buy a nut for the bolt to run through at the bottom it’s a m10.125 btw)
Also got some wheels other than what was on the car. What do y’all think
#37
thank u sir. I didn’t think I was going to like those rooms as much as I do but yeah you are right I’m going to have to roll my fenders for sure. I’m not going to slam it. Just low enough to conceal the fender gap
#38
#44
#48
So I just ran into a issue my charge pipe on the passenger side is not long enough, so I have to find one for a EK specifically I’m guessing or call up at go auto works.
#49
Well guys i might need some help.
Got everything in. Uploaded base map to start it. (Only thing i did was select 4 bar map sensor and did the fuel for the injectors.) Tuning software is s300 v3 , it cranks but not start, it wants to start if i give it gas. It’s almost like it’s flooding out. 🤦🏻*♂️
#50
What base map did you pick? What injectors you using and what settings do you put in the injector parameters? What fuel are you using? Got fuel pressure?
Check mechanical timing is good?
