97 civic electrical problem !HELP!
Old 09-29-2009, 08:32 PM
dcmonkey's Avatar
Icon6 97 civic electrical problem !HELP!
ok so the other day i was driving my kupe to my mothers house and i hit a "not so bad bump" and all of the sudden i got a CEL, pulled the codes and i got two codes for o2 sensors,1 for vacume leak and 1 for a faulty speed sensor total of 4 codes( codes for tech referance are ;p1298-p0135-p0141-p0501)
well i thought nothing of it since she was still running great... later on the same day i went to drop my girlfriend off and the lights started to dim... everything that was lit was beggining to dim. I dropped her off and on my way home( literally around the corner from her house) she dies..no battery light to warn me...... CRAP, luckily a cabbie jump started my car up and she survived the short ride home... long story short i did some trouble shooting and figured fuse #15 a 7.5fuse in the underdash panel keeps blowing out which is "alternator/SP sensor" MAKES SENSE right since my speedo isnt working aswell..... anyway im guestimating theres a short somewhere that the little dip i went through triggered it.........
i tried putting a 20amp fuse and she blew it as soon as i reved her slightly
HAS ANYONE HAD ANY EXPERIENCE WITH THIS SAME OR SIMULAR ISSUE.... PLEASE HELP
Old 09-29-2009, 08:48 PM
Former User's Avatar
Default Re: 97 civic electrical problem !HELP!
Common problem. Read this TSB.
Old 09-29-2009, 09:22 PM
dcmonkey's Avatar
hey RONj the link did not work for me dude....anyone else or can you please re-direct me RON??
Old 09-29-2009, 09:25 PM
It's a link that downloads a PDF of the TSB to your computer. Look for the download.
EDIT: Sorry, my link was bad. Fixed. Try it again.
Old 09-29-2009, 09:37 PM
dcmonkey's Avatar
dude ron ive seen a shittier version of that image and couldnt understand it but duude you are freaking awesome......i shall fix my japanses stallion tomorrow.
ill post if this fix works or if i find any cruded up wires
Danny
Old 09-29-2009, 10:00 PM
Old 09-30-2009, 03:34 PM
dcmonkey's Avatar
thanks for the info RON the problem is now solved and im back on the road..... i got another problem which is not so serious though, my horn doesnt work.... i used a test light for the plug which is on the horn and no juice , but when i go directly to the underhood fuse box and tap into the fuse with the light it lights up. the fuse is fine btw. is there something that i am missing here???? i cant seem to locate the relay care to help again RON??
Old 09-30-2009, 08:56 PM
Remove the driver's airbag from the steering wheel and check for battery voltage at the horn connector.
Old 10-02-2009, 02:13 PM
dcmonkey's Avatar
so common sense says if theres no juice to the horn plug under the bag BUT theres juice to the underdash fuse box theres a break in the wire somewhere from there to here.....right
Old 10-02-2009, 02:35 PM
Right. Did you use the horn ground for the voltage test? If so, test it for continuity to ground. If the ground wire is fine, then test for an open in the hot horn wire between both ends of the clockspring/cable reel under the airbag.
Spitz911
04-08-2014 04:12 PM
Lewis7789
06-12-2007 02:22 PM
the_illest_soldier
09-10-2005 03:12 PM
dvang
10
01-05-2005 09:35 PM
Quick Reply: 97 civic electrical problem !HELP!
